LX-mini Crossover Article
Thread Tools
Old 2nd January 2021, 10:12 AM   #791
peterhenk is offline peterhenk  Netherlands
Default Found it (I guess)
Found it, sorry for the posts
Originally Posted by peterhenk View Post
Happy new year everybody
I would like to use the LX-Mini board to filter my home brew OB's (typical 2 woofer + FR) and was wondering what section of the board I need to use (and how to populate it) to create the Bass bump that was incorporated in the First Watt B5. With some hints I will try to use the simulation software and get the results.
Hope I don't ask something that has been discussed already (I could not find it)
Peter
Old 22nd January 2021, 12:35 PM   #792
Adam82 is offline Adam82
Default Number of ACNs for a pair of LXMinis?
Hi All,
I have skimmed through the thread, but didn't really find the answer I was looking for. The question is rather dumb I guess. I'm a total amature and this would be my first DIY project apart from the LXMinis (build still pending). If I understand correctly, I would need to build 2 ACNs for a pair of LXMinis?
That is, I need two boards and the rest of the package, am I right?
Thank you,
Adam
Old 22nd January 2021, 01:18 PM   #793
wcwc is offline wcwc  United States
Each board is two channels. So you would only need one board if you are using RCA connectors.
Old 22nd January 2021, 02:27 PM   #794
Thank you, ordered the kit.
Old 29th January 2021, 09:44 AM   #795
cube75 is offline cube75  Netherlands
Hello Pass diy fans,
Is it possible to combine the LO and HI site of the board to create a high pass and low pass for a single driver?
In this case , I would have maximum control over the resulting acoustic response of that particular driver because of the eq sections.
Ronnie
Old 29th January 2021, 02:49 PM   #796
Khangln is offline Khangln
Happy New Year DIYer,
I will receive my board next week, now I'm preparing the part list. As my understanding this xover's cut off frequency with default part is around 600hz. Correct me if I'm wrong?
Anyone has tried to cut at 800hz?
Old 29th January 2021, 08:13 PM   #797
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Yes. Just take the output of one filter and feed it into the other.
Old 26th February 2021, 10:23 AM   #798
more10 is offline more10  Sweden
The kit is a bit confusing. From the number of connectors on the box one could make the conclusion that the board is 3 way stereo. Or 3 way mono balanced. But the box could hold two cards...
I want to build a 3-way balanced stereo so I guess I need 4 cards. Correct?
Old 26th February 2021, 12:37 PM   #799
ogawas is offline ogawas  United States
Hi all,
I recently upgraded from the 2 way ASP to the 3 way ASP.
https://www.magiclx521.com/epages/17...20mini%20NP%22
I now have the 2 way ASP sitting on the shelf. If interested in buying, send me an email to ogawas@yahoo.com and we can talk. I will be posting this ad in the swap meet area if I don't hear from anyone here. Selling within U.S. / 48 contiguous states. I will be keeping the power supply so you will need to provide your own PS.
Thanks.
-stu
Old 4th March 2021, 09:20 PM   #800
escucalin is offline escucalin
escucalin's Avatar
Mr Pass what is your opinion of a RL version of a passive crossover; would you suggest such implementation attempt?
LX-mini Crossover ArticleHide this!Advertise here!
Thread Tools
Lx-mini Analog Crossover Nelson Pass Analog Line Level 27 10th April 2021 03:15 PM
Analog Crossover for LX-mini Nelson Pass Multi-Way 1 7th July 2018 09:51 PM
AES article on the ultimate active crossover hahfran Analog Line Level 3 17th May 2016 04:39 PM
Mac Mini dual DAC crossover OzMikeH Digital Line Level 2 12th January 2009 10:11 PM
Mini Crescendo article carlhemm Solid State 6 4th December 2006 04:37 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
