LX-mini Crossover Article
LX-mini Crossover Article Please consider donating to help us continue to serve you.
Old 8th November 2019, 05:59 PM   #621
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
I think what you will like about this one is the +/- 1 octave adjustment range
of each of the 1 - 4 poles per filter. Gives some adjustment wiggle room you don't
normally get.
Old 9th November 2019, 11:09 PM   #622
JuleZ3C is offline JuleZ3C
Yeaaahhh, bring it on baby! hmm Sir!
Getting tired of my low humming, 'did-it-myself' POS proto board(s)
Adjustment range sounds very cool indeed!
Old 10th November 2019, 12:55 AM   #623
The one and only
BTW, I am bringing a few LXmini crossover kits - board, semis, resistors, caps
to distribute at BAf tomorrow.
Old 10th November 2019, 07:44 AM   #624
cubicincher is offline cubicincher  Germany
Default to Nelson Pass #621
Hello Mr. Pass,
this will become a very nice active crossover!
One octave adjustment per pole sounds very good.
Thanks for your efforts on this project. I think you are extremely busy before BAF....
Greets
Dirk
Old 11th November 2019, 02:53 PM   #625
signalbeach is offline signalbeach
normally get.
Hi Nelson,
Will it be possible to use the new crossover in a balanced configuration with 2 poles per filter ? If so, do you recommend any component matching between the + and - phases if operating balanced ?
BTW, I'm using a Pass Int 250 integrated amplifier. Is there any easy way to bypass the preamp section of my Int 250 ? I probably need to implement a master volume control and input switching separately.
I'm excited to see the crossover. Thanks for all your efforts for the DIY community !
Old 11th November 2019, 03:40 PM   #626
chromenuts is online now chromenuts  United States
Ignore me...did some back reading. Thanks for this Pa.
Old 11th November 2019, 06:29 PM   #627
The one and only
Originally Posted by signalbeach View Post
Hi Nelson,
You can tap into the points on the existing board, and may have to cut
some traces, but it can be done. Easier just to get two of them and use
one board for each balanced channel.
I don't know about the bypass of the INT250 preamp. We will have to
ask Wayne.
Old 3rd December 2019, 01:01 PM   #628
DUC985 is offline DUC985  Germany
Can somebody enlighten me how the EQ works and how to calculate the values. I did try to modify the values to reflects a 250Hz Crossover with a 40HZ bump for an open baffle.
My initial thoughts are to leave the EQ out ...
Old 3rd December 2019, 09:49 PM   #629
The one and only
It's not a "standard" circuit, but is easily simulated. The schematic you see can
be entered into MicroCap (free from spectrum software) and you can play with it
until the cows come home....
Old 4th December 2019, 08:14 AM   #630
thx Nelsom, i understand what it does, sounds like a specific requirement for the LXMini so speaker specific ..
LX-mini Crossover ArticleHide this!Advertise here!
Lx-mini Analog Crossover Nelson Pass Analog Line Level 21 20th October 2018 01:37 PM
Analog Crossover for LX-mini Nelson Pass Multi-Way 1 7th July 2018 10:51 PM
AES article on the ultimate active crossover hahfran Analog Line Level 3 17th May 2016 05:39 PM
Mac Mini dual DAC crossover OzMikeH Digital Line Level 2 12th January 2009 11:11 PM
Mini Crescendo article carlhemm Solid State 6 4th December 2006 05:37 PM
Copyright ©1999-2019 diyAudio
