LX-mini Crossover Article
Old 26th February 2019, 05:10 PM   #461
Rewind is offline Rewind  Sweden
Rewind's Avatar
Awesome!
Old 26th February 2019, 05:22 PM   #462
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
Finished my build and am enjoying them as I type. I agree with avdesignguru's comments quoted below. For me, the best feature is the improved bass control. If I had a miniDSP version of the LXmini and didn't want to go analog, a good step would be to try to match the NP crossover in the miniDSP, especially for bass.
Originally Posted by avdesignguru View Post
1) More headroom, lower overall noise floor. MiniDSP D-to-A outputs are a circuit design weak point.
2) Less woofer over-excursion, reduces woofer distortion
3) Smoother upper mid-hi equalization, reduces phase shift problems introduced by the Linkwitz DSP filter design which actually detracts from any benefit of the more precise EQ
Overall sound is smoother and more listenable, with no loss of detail. No noise, hiss or hum.
I wanted to take a minute and thank Nelson for this project and all the other DIY projects he has shared. I didn't know SL personally, but I followed his work over almost 40 years. I think its great that you and SL worked on this in the later days of his life. I'm sure it meant a lot to him and means a lot to us as well. Thanks for all the lessons, Prof. Pass.
Jac
Old 5th March 2019, 06:00 PM   #463
deploroman is offline deploroman
Default XLR mono block wiring question
Pardon if dumb question, but purchased second kit recently with intent of wiring to use xlr cabling. What's trivial to you all raises questions for me...been a long time since circuits class, and I got one of those other engineering degrees.
Just use one side of board for + i/o and other for -? Do I invert?
Lastly, would you advise against just running wire from RCA posts to xlr jacks as appropriate, starting from the board wired for the unbalanced i/o?
Old 5th March 2019, 06:18 PM   #464
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Using two of the crossover boards for balanced implies having a
balanced source, in which case the + signal goes through one channel
and the - signal goes through the other.
This works if your connections are balanced input and output. It does
not create a balanced/unbalanced conversion.
Old 7th March 2019, 02:45 AM   #465
Much obliged for taking the time to respond Nelson. I'm sure you have lot's of more exciting to do. I think I got you're drift...I'm over thinking it.
Old 11th March 2019, 01:00 PM   #466
gadut is offline gadut  Indonesia
gadut's Avatar
if i use bipolar psu, should I connect Vref to (G) and Gnd to (-) supply? I have not populated the psu parts on this board yet.
I'm using salas bib to power dcb1 board, they will be housed in the same chassis.
AD1865||DCB1||FW PSU||J2||M2||SIT L'Amp||Open Baffle
Old 11th March 2019, 02:03 PM   #467
wcwc is offline wcwc  United States
The crossover boards require 24V differential voltage. You could supply it 0-24V with the positive side of the regulator or feed it with +/- 12V bipolar supply. Nelson addressed my question on the subject many pages back.
Old 14th March 2019, 11:06 PM   #468
tecnofossil is offline tecnofossil  United States
Default LX Mini crossover
A question about the FET buffers used in the Lx Mini. Lord Pass (not to be confused with Lord Lucas, father of darkness ) has offered 2 different buffer circuits, one a pair of complimentary FETs, the other, incorporated in the first crossover kit, an FET with current source. Which one would be more suitable for driving long shielded interconnect cables and /or RC filters? Or do they perform the same?
Thx!
Old 15th March 2019, 05:59 PM   #469
The one and only
The Toshiba/Linear Systems complementary parts will deliver more current
and have a lower output impedance than the single-ended Fairchilds at a cost
of 5 to 20 times the price.
Ordinary loads, this is not a big deal. the Fairchild buffers are optimized around
10 Kohm and 1,000 pF.
Old 17th March 2019, 12:07 AM   #470
That answered it. Thank you!
-T
LX-mini Crossover ArticleHide this!Advertise here!
Lx-mini Analog Crossover Nelson Pass Analog Line Level 21 20th October 2018 12:37 PM
Analog Crossover for LX-mini Nelson Pass Multi-Way 1 7th July 2018 09:51 PM
AES article on the ultimate active crossover hahfran Analog Line Level 3 17th May 2016 04:39 PM
Mac Mini dual DAC crossover OzMikeH Digital Line Level 2 12th January 2009 10:11 PM
Mini Crescendo article carlhemm Solid State 6 4th December 2006 04:37 PM
Copyright ©1999-2019 diyAudio
