LX-mini Crossover Article
Old 7th October 2018, 05:18 PM   #171
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Originally Posted by nzlowie View Post
Does this have a hi pass on the low frequency section? My plan was to replace the passive xover that's on my mid/hf horn's, I use a DSP bass amp for the bass section. So I have DSP and amp for bass then another amp and passive xover for the mid/hf section.
Was looking to keep the DSP bass amp and use this active xover for the horns but then realised it probably doesn't have a hi pass at its lower end, is this correct?
It does have a high pass on the bottom end. It is adjusted for high Q
to provide a 5 dB bump up at 50 Hz, but it's a simple 2 pole topology
and you can stuff it as you like.
Old 7th October 2018, 05:22 PM   #172
The one and only
Originally Posted by Manolo47 View Post
Reading the article Nelson mentions that FL considered or used as parameter in this design -correct me if I’erong in this - that the minimum power rating for the amplifiers to be used in conjunction with this xover were 80 and 100. Is this really so? Us owners of FW Amos would then be disqualified...
And the volume controls. Why are there 4 controls? And if one uses, let’s say Alps attenuators in the faceplate, how would these be implemented. I would only use one for the low pass section... would it be just one? Thanks.
Siegfried and I sat down one day with LX minis. a digital scope and a
copy of Telarc's 1812 overture with the cannon shots. We played it at
what SL determined to be an adequately loud level and measured the
peak wattage from each amp, top and bottom.
The result was performance where a 75+ watt amp would do it on
the bottom and a 25 watt amp on the top.
Old 7th October 2018, 05:23 PM   #173
Stanney2017 is offline Stanney2017  United Kingdom
Thank you!
Old 8th October 2018, 10:59 AM   #174
Manolo47 is offline Manolo47  Puerto Rico
Thanks! And, what about the 5db hump at 50 hz, can that be moved to a lower frequency,, like 20 Hz?
I would be using this as a HP filter for my Spatial M4's , set at either 80 or 120 Hz and a corresponding LP filter to my "Ripole" subwoofers, would it work well for this?
I presently us a minidsp 4hd -which really is pretty good though one can instantly experiment will all kind of parameters to see which work, and sounds pretty good also.
Old 8th October 2018, 04:51 PM   #175
The one and only
It's a filter. You set the values and there it is. You can put the hump
where you want it by scaling the resistor/cap values, and you can adjust
the amplitude of the peak also.
Whether it works well for you depends mostly on R/C value choices you
make...
Old 10th October 2018, 10:53 AM   #176
Default User's manual?
So, would a user's manual be offered with information as to how implement the different filter options, etc.? And would the kit have various resistors and or cap values so one can experiment with let's say, 80 hz vs. 120 hz. Xover frequencies or I would need to buy these? Thanks!
Old 10th October 2018, 11:42 AM   #177
Dennis Hui is offline Dennis Hui  Canada
Default pot adjustment
I have a dumb question about setting up the volume/pots of the
crossover. Assuming one amp has higher gain than the other,
the pot for the lower gain amp should be set wide open.
For the other amp, can we simply set the corresponding pot so
that both amps give the same voltage output with an input at
approx 580Hz? (I'm going by the crossover response
graph on p13 of
http://www.firstwatt.com/pdf/art_lxmini%20crossover.pdf
where the red and blue lines intersect.)
Thanks,
Dennis
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 10th October 2018, 03:26 PM   #178
Davey is offline Davey  United States
Dennis,
You could do it that way. But I think the easiest/best way would be to just the appropriate potentiometer downwards until it sounds best to you.
Dave.
Old 10th October 2018, 05:26 PM   #179
The one and only
My intent was to put up a simulation template in MicroCap so that people
could play with values and see the results.
Old 12th October 2018, 01:15 PM   #180
escucalin is offline escucalin
escucalin's Avatar
Hello,
How are the jfets involved matched? I have experience measuring the drain source current when Vgs=0 or the gate connected to source; is it the case? Or it needs the gate resistor added for a more precise Ids?
I am investigating a way to use a stock of old jfets (i accumulated over the time) from the audio era; and use them in this superb active crossover.
LX-mini Crossover ArticleHide this!Advertise here!
Lx-mini Analog Crossover Nelson Pass Analog Line Level 19 27th August 2018 03:32 PM
Analog Crossover for LX-mini Nelson Pass Multi-Way 1 7th July 2018 09:51 PM
AES article on the ultimate active crossover hahfran Analog Line Level 3 17th May 2016 04:39 PM
Mac Mini dual DAC crossover OzMikeH Digital Line Level 2 12th January 2009 10:11 PM
Mini Crescendo article carlhemm Solid State 6 4th December 2006 04:37 PM
