LX-mini Crossover Article
Old 21st September 2018, 06:50 PM   #101
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Originally Posted by RemcoB View Post
Mr. Pass, is the Toshiba/Linear Systems board still in the pipeline? If not, I'll order the 'regular' version.
It only requires a minor artwork change for the different pinouts. If the
store wants to handle it, I can provide the board.
Old 21st September 2018, 09:05 PM   #102
RemcoB is offline RemcoB  Netherlands
Dear Mr. Pass,
If you could indeed provide the board for the Toshibas / Linear Systems, that would be superb! I built the smaller size SLOB with Coral Beta 8s and Eminence Beta 15As, thus I want to build the b5 as I'll have to tame the rising response in the treble (ca 10-14 kHz) and use the equalization for bass boost.
Thank you so much,
Remco
Old 21st September 2018, 09:45 PM   #103
cspirou is offline cspirou  United States
Would this mean it would still be a single-rail power supply and capacitor coupled?
Old 21st September 2018, 11:04 PM   #104
The one and only
Yes.
Old 22nd September 2018, 10:43 AM   #105
joe is offline joe  Germany
I am also interested in a Toshiba version.
If the shop doesn't take the bait I am also happy with just the Gerber-files.
Old 22nd September 2018, 06:44 PM   #106
The one and only
Whatever happens, it has to wait on the big list....
Old 22nd September 2018, 09:22 PM   #107
dBel84 is offline dBel84  United States
I might be being completely daft but the LX-mini XO is only 2-way. The chassis looks like it is 3 way ( which is what I am after ) - does this mean there is an imminent release planned for a 3-way design? I know NP had mentioned a 3-way in the original article.
just curious..dB
Old 22nd September 2018, 10:08 PM   #108
The one and only
We wanted to make allowances for future projects, including LXmini+2
and triamps and also preamps with 3 inputs, etc.....
Old 22nd September 2018, 10:43 PM   #109
mcluxun is offline mcluxun  United States
just curious..dB
Also the chassis has balanced in and out.
Will that be supported by current PCBs?
Old 22nd September 2018, 10:55 PM   #110
wcwc is offline wcwc  United States
Balanced requires two boards. I ordered 2 kits for that purpose. I plan to put them in boxes located under the stereo amps driving the lx-mini's. One for the left channel and one for the right channel. I am getting a different sized chassis which matches the footprint of the amps.
LX-mini Crossover ArticleHide this!Advertise here!
Lx-mini Analog Crossover Nelson Pass Analog Line Level 21 20th October 2018 01:37 PM
Analog Crossover for LX-mini Nelson Pass Multi-Way 1 7th July 2018 10:51 PM
AES article on the ultimate active crossover hahfran Analog Line Level 3 17th May 2016 05:39 PM
Mac Mini dual DAC crossover OzMikeH Digital Line Level 2 12th January 2009 11:11 PM
Mini Crescendo article carlhemm Solid State 6 4th December 2006 05:37 PM
