Aleph5 more mosfet output
Hello,
I am building Aleph5 and I want to add more output mosfet without changing of the bias per device. So, I will get more total bias which could be better in sonic performance.
My curious is, should I just put more mosfet in parallel (with source and gate resistors) and don't have to adjust any surrounding component? Or do I have to change the output resistors or source resistors value?
Thank you in advance for every answer.
as is , with 1R source resistors , that will be 0A5 per vertical pair
so original, having 3 verticals , that is 1A5 Iq
with your 5 verticals , that will be 2A5
with 5 verticals, each source resistor 1R, you need 71mOhm in sense group , to stay in same guidelines
What if I use the same value for source resistors and output resistors. What gonna happen?
