Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Pass Labs This forum is dedicated to Pass Labs discussion. |
Thread Tools |
#5051 |
Good to hear. Hopefully, I'll be up and running sometime this coming weekend.
Regards, Dan ![]() |
#5052 | |
if I see correctly in the picture (post 5026), you have the speaker gnd blue wires going to the amp board, when I did that my amp exhibited a slight hum as well which I attributed to some type of gnd loop. That goes away completely when I connect the speaker gnd to the star gnd on the PS. I saw this point discussed somewhere around here before. Worth a try to rewire. Last edited by grataku; Today at 04:59 AM. |
#5053 |
Thanks grataku
![]() I have already done the combinations with wiring so this option has already been checked. With no result. However, having a transformer outside the chassis , I will also check it again. |
#5054 |
Hello hayenc,
the dimbulbtester - phenomena is well known with the M2X: If you switch the M2X on the dimbulbtester dims down/ or goes off (then everything is o.k. with your M2X) and after a few seconds the bulb comes back shining. It is the same on my M2X. Also other members reported about this behaviour. Greets Dirk ![]() |
#5055 |
Freedom or Death
hayenc, that behavior you had was normal for the M2.
here's how it goes, light comes in bright as the large caps charge, they reach charge and then dim down, it takes a bit to bias up the circuit.... it comes in slowly and the light will again get brighter. It depends on the wattage of the bulb, just how bright it will get.
Who's your Daddy? Pappa of course. ![]() |
#5057 | |
Hoping for music this afternoon. |
#5058 |
I pushed the transformer back really far. This is what the ARTA graphs look like. On the second, when the edcor output is shorted.
Attachment 944378 |
#5059 |
Next step
Power transformer setting and 50Hz noise. It is different for each channel. I have to find a common pointlewy%20kana%C5%82%20trafo%20na%20godzin%C4%99%2010.jpgprawy%20%20kana%C5%82%20trafo%20na%20godz%209.jpgJPEG_20210420_232047_4872055441746900396.jpg |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
What make and model are the original drivers in Wilson Watt&Puppy 7 (WATT) | aguiarrj | Multi-Way | 17 | 24th June 2017 10:39 PM |
2.3 watt x 4 or 5 watt x2 SET amplifier using DECWARE Zkit1 and Zkit4 schematics | Redwolf92 | Tubes / Valves | 12 | 29th October 2014 10:19 PM |
diyaudio moderator vs diyaudio member | Leolabs | Everything Else | 6 | 18th June 2006 08:19 AM |
New To Site? | Need Help? |
