The amplifier pictured below has been my experimental platform for the past few years. You would get a laugh if I added a pic of the bottom plate...looks like it was used for target practice. Currently installed are the Toriody trans w/ 22V secondaries, H9KPXG on-off/soft start/relay, SLB PSU (in place of the Universal board), M2X circuit boards (formerly an F4, M2, and then Aleph J), and Ready-to-Run SSR speaker protection.... how many volts on a +/- power inputs does it take to "activate" the M2 circuit?
So to answer my own question, here's what happens at various settings while bringing the voltage up slowly. I would stop for a bit at each of the settings (maybe 1 to 5 min.) and make some notes.
*10% on Variac - Nothing, there isn't enough power to trip the relay on the H9KPXG, only the "OFF" LED will light up at this point.
*20% - Relay now closes, and powers up the SLB PSU lighting it's LED's, but no readings on either source resistors, or outputs (offset).
*30% - Starting to read some voltage on the source resistors, offset is wonky but steady.
*40%-50% - Source resistor voltage increasing but no AC output when given a smallish (500mV) input.
*60% - Starting to produce a AC output (nice sine wave on scope) given an AC input.
From there I went straight to 100% and adjusted offset to ~0.
Connecting it to speakers and source produces nice sounding music, but also a bit of hum with ear close to the speaker. Ugh, now I have to chase down that hum. Funny thing is there was no hum (dead quite) with the Aleph J boards installed. Any ideas on the hum...all are welcome.
Currently there is no shielding on the M2X transformers, I'll try that first and report back.
Lot's of porn for ZM...
Kevin,
First of all, excellent build. I really like how you vertically mounted your Toroidy. I have never done that with any of mine so that definitely looks cool and serves the purpose of keeping the toroid far and away from sensitive circuitry.
Thanks for the info on what point the source resistors (and hence Mosfets) start conducting depending on the AC line voltage. That’s useful.
The interesting thing is I have a similar setup to yours including the large well shielded and encapsulated Toroidy. So I am praying I don’t have hum since as you have pointed out, the Edcor transformer is unshielded in stock form. I think you are on the right track to making a mu metal enclosure for the transformer, there are countless examples on this thread. I just put a mu metal wrap on mine.
Suggestions for chasing down the hum (you’ve probably already addressed these and thought of them):
-Consider tightly twisting and braiding the AC wires from your Toroidy, both the primary and secondaries, and shortening them. Make sure they are far and away from the main amplifier boards, particularly the Edcor unit and definitely the input stage area.
-This would also mean that your rectified DC wires need to be far away from the AC wires from your Toroidy transformer. Twisting your DC wires is an option as well.
-I seem to recall there were individual right and left main boards for this design so swapping them might help in minimizing the length of the input wiring?
- At the same time, suggest swapping your Toroidy to the opposite side, if you know what I mean. I’ve seen more examples of fellas mounting it vertically towards the front panel.
-If you have a true RMS voltmeter, you should be able to measure what your AC hum is on the speaker outputs, although I prefer a scope and/or my HP3478 (a bench meter with 100khz bandwidth). Don’t know what tools you have. I try to aim for 1mV RMS max for solid state amplifiers (if possible!).
Those are my suggestions but I’m sure there are other varieties one can try.
Good luck, I’m sure you’ll do fine!
Best,
Anand.
Best,
Anand.
Oh, I have all the tools...I just don't use them very well.If you have a true RMS voltmeter, you should be able to measure what your AC hum is on the speaker outputs, although I prefer a scope and/or my HP3478 (a bench meter with 100khz bandwidth). Don’t know what tools you have. I try to aim for 1mV RMS max for solid state amplifiers (if possible!).
I’m trying to learn how to measure ripple and noise on the DC power supply, and noise at the amplifier outputs. As I make modifications (twisting and shortening wires, shielding transformers, etc.) I’d like to know if I can “see” the difference before listening to it. I’ve been watching videos and reading papers. While I’ve learned a bunch, I haven’t found anything showing exactly how to measure the noise on an audio amplifier output. If anyone would care to help, or put me in the right direction it would be greatly appreciated.
^ Not sure what equipment you have on hand, but... almost without a doubt, the best thing I did was learn to use a pair of cheap earbuds (of course be careful) connected to the speaker outs with inputs both shorted and not shorted while moving things around and twisting etc. Of course that's over-simplified, but ... Someone around these parts had an attenuator / PCB specifically for that if I'm not mistaken... I truly don't remember, but if someone sees this they may be able to point you in the right direction.
As for an "easy" way...
https://quantasylum.com/products/qa403-audio-analyzer
Certainly not a budget way... and it's not the world's lowest noise floor, but it sure does make it easier for someone like me that's trying to learn.
Shame on you for tempting me to buy yet another toy...Bad, Bad, Bad.As for an "easy" way...
At this point I have an O-Scope, Differential Probe, Bench & 2 handheld meters, Signal Generator, Autoranger/Sound Card/Spectrum Analyzer (software on PC), Bench Top PSU, Dummy Load, Variac, DBT, MEGA 328, and maybe some stuff I can't remember. Still learning how to use most of it...Not sure what equipment you have on hand...
While no solution to measuring noise, I wonder if a simple inductive amplifier would be helpful in locating the root of hum or buzz. I'll pull out my toner and probe the next time I fire up a channel just out of curiosity, but maybe someone more knowledgeable can offer some input.
Depending on the sound card ... that might be enough. I haven't tried it with an internal sound card on a PC, but I believe I've seen it done. I've done noise measurements with REW + Focusrite. X and the group over in the "REW thread" are incredibly helpful.At this point I have an O-Scope, Differential Probe, Bench & 2 handheld meters, Signal Generator, Autoranger/Sound Card/Spectrum Analyzer (software on PC), Bench Top PSU, Dummy Load, Variac, DBT, MEGA 328, and maybe some stuff I can't remember. Still learning how to use most of it...
Basically, you're (with proper wiring) just hooking up the outputs of the amp with no signal to the 'tester' and checking the output. People do certain weightings through software, but you'll pretty quickly see what the frequency of the hum / noise might be if there is a predominant one present and it's level relative to a known point and/or if you calibrate it to a known voltage.
Just to tempt you... this takes <1 minute to do with the QA... My Aleph 60 noise. A-weighted.
Still learning a bit how to set up properly each time, measure it the same way each time, and digest it all, but ... look at the pretty colors!
With an oscilloscope you can start by checking the power supply ripple and the amplifier output noise.
The power supply with capacitance multiplier should have less than 5mV ripple but that should be measured to hopefully eliminate it as a source of the noise. To check for ripple connect the probe ground to PS ground and probe to PS V+ and check for ripple voltage. Repeat for V-.
If that checks out, then make sure the amplifier input is shorted, attach an 8 Ohm load to the speaker output of one channel, probe ground to load ground, probe to load positive, and check for output noise.
There is a lot of information and instructions on the web on measuring noise using an oscilloscope.
Post the oscilloscope screen shots for review.
Amplifier noise can be difficult to assess without measurements since people have speakers of various sensitivity. A person may hear no noise from low sensitivity speakers but have a noisy amplifier. Their amplifier may have many construction issues but they are sure that their amplifier was built to the highest standard, and that details such as grounding, layout, twisted wires, etc. are not important since they do not hear any noise. Conversely a person may hear a bit of noise from high sensitivity speakers, and the amplifier was constructed with proper detailing for low noise but it may have a level of noise that is appropriate for its type. Or an amplifier may be very quiet and no noise is heard from all speakers.
The M2X with its unshielded voltage gain transformer is the noisiest of all First Watt type amplifiers. So noise may be audible if your speakers are very sensitive. The FW M2 Specifications specify a noise level of 500uV.
O-scope settings: AC coupling, BW Limit ON, 1X probe. Vrms measurement jumps around anywhere from 1.7 to 3.8mVTo check for ripple connect the probe ground to PS ground and probe to PS V+ and check for ripple voltage. Repeat for V-.
8mV ripple is not bad. As for the frequency, if the horizontal axis is 50us per division, then the period is approximately 40us, and frequency is 1/0.000040s=25 kHz.
Try changing the time base so that the horizontal time is more than 50us per division. For instance, 60Hz period is 16.666ms. So you want something in that neighbourhood, perhaps 20ms per division. Or 10ms or even 5ms per division.
Did you measure the amplifier audio output?
Similar to what a regulator would require, the SLB capacitance multipliers will benefit from bulk storage capacitance on their output. At least 10,000 uF, and 36,000 uF better still. This is covered in Nelson's article on regulators. I have found the difference to be noticeable.
The spikes are at 120Hz but the ripple is low. Generally ripple is lower when the current is low and higher when the current is high. I assume the power supply was not connected to the audio boards.
There is also a background of high frequency noise at a low voltage.
The questions of the spikes and high frequency noise are probably best asked on the SLB thread and perhaps xrk971 can provide answers:https://www.diyaudio.com/community/...ct-crc-cap-mx-class-a-power-supply-gb.336479/
- The diyAudio First Watt M2x
