The diyAudio First Watt M2x
Old 30th June 2020, 07:54 PM   #3251
grataku is offline grataku  United States
Ain't nobody got time for flimsy enclosures ;-)
Old 30th June 2020, 07:58 PM   #3252
thompsontechs is offline thompsontechs  United States
Freedom or Death
thompsontechs's Avatar
I'm feeling a bit of inadequacy when admiring that fine piece of metal.
Who's your Daddy? Pappa of course.
Old 30th June 2020, 08:13 PM   #3253
TungstenAudio is online now TungstenAudio  United States
Given the proximity of the Edcor transformers to the middle of the case, you will definitely need to use a well shielded power transformer. The Antek AS-4218 has a steel outer case available for it. Place it as far forward as possible. The store PSU boards are a good start for a decent supply. Your choice of rectification will yield about 22V to 23V on the rails.
Old 30th June 2020, 09:04 PM   #3254
@Tungsten,
the case maybe wider than it appears. Here is a shot with the trafo and the butta' board.
I went for the mosfet position being centered onto the heatsink for optimal cooling. I can build something arounf the trafo if it needs it.
I am used to transformers outputting more Vs than needed and being undersized in Cu meaning they wind a whole bunch of extra coils so that the voltage settles to the rated V under full load. Historically, I always upsized my transformer chasing that deeper bass...
I decided to not do that this time.
I am using an antec 200VA 18+18 which looks plenty big enough to support the system. We'll see how that goes.
Old 30th June 2020, 09:50 PM   #3255
Unfortunately a single Antek AS-2218 will not be sufficient for that build. A pair would work if you were willing to go with a dual mono configuration, without the SLB CapMx boards. Due to the voltage dropout of the capacitance multiplier, you would need transformers with 20V secondary windings to get the preferred voltage on the rails.
Old 30th June 2020, 10:00 PM   #3256
We'll see. I don't plan to use the cap multiplier for now. Worse2worst I will get a new trafo but I will make this work.
Old 30th June 2020, 10:09 PM   #3257
Freedom or Death
I have a 3218 sitting on my bench, if ya need it, lemme know.
Old 30th June 2020, 10:29 PM   #3258
Thanks for the offer!
3218 is only 300VA and power is not the limiting factor here. IMO anything above 200VA is a complete waste for this amp. If I go with regulator I may need to notch it up to 20 or 22V.
Old 30th June 2020, 10:35 PM   #3259
Freedom or Death
Well, in that case, I have 2x22 sitting on the bench.
Old 30th June 2020, 11:38 PM   #3260
You 'goldy locks' it? 18 too little, 22 too big 20 just right? :-D
The diyAudio First Watt M2xHide this!Advertise here!
What make and model are the original drivers in Wilson Watt&Puppy 7 (WATT) aguiarrj Multi-Way 17 24th June 2017 10:39 PM
2.3 watt x 4 or 5 watt x2 SET amplifier using DECWARE Zkit1 and Zkit4 schematics Redwolf92 Tubes / Valves 12 29th October 2014 10:19 PM
diyaudio moderator vs diyaudio member Leolabs Everything Else 6 18th June 2006 08:19 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
