The diyAudio First Watt M2x
Old 21st June 2020, 05:41 AM   #3241
borlotti is offline borlotti  Germany
If someone is interested in the plugs,
I would buy the plugs here in Germany,
and ship them at the cost plus shipping costs.
Old 22nd June 2020, 07:01 AM   #3242
freejazz00 is offline freejazz00  United States
Might make sense if the order were large enough. Only place I could find them domestically is here
132C12019X | Conec Distributor | 132C12019X Inventory
Old 22nd June 2020, 07:10 AM   #3243
as I said, who wants to have such plugs,
can contact me and I do this at cost price.
Old 22nd June 2020, 09:47 AM   #3244
Bones13 is offline Bones13  United States
Techie Wanabe
Bones13's Avatar
@borlotti are the nylon standoffs on your built for a purpose? I’m thinking you will mount a metallic shield to prevent hum?
At €1 per connector part, I’m figuring that
8 female and 40 male, it will cost €48 euro, if I understand correctly.
M2x monoblocks - Zu Audio Druid V
(Analog) Technics SL-1200G - K&K Audio Maxxed Phono. (Digital) Bricasti M12
Old 22nd June 2020, 05:38 PM   #3245
thompsontechs is offline thompsontechs  United States
Freedom or Death
thompsontechs's Avatar
Well, I went back in and swapped out those Carbon Comp resistors... Wasn't bad, I have had plenty of practice de-soldering. lmao
Who's your Daddy? Pappa of course.
Old 24th June 2020, 07:00 AM   #3246
Default connectors
I requested the connectors directly from the manufacturer this morning. Number of pieces for 10 x complete assembly of the boards, which are each a set with 8 sockets and 40 plugs. as soon as I get the prizes I'll get back to you.
Old 25th June 2020, 04:45 PM   #3247
Freedom or Death
Okay, dropped in the Antek with 20V secondaries and I'm now in the ball park... As some rad above, I had some 22V secs from another project and was going to use them, but I was getting almost 28V rails even with the SLB supply.
I have 24.4 as a low and I can take it up to about 26.5 on the rails. BTW the one mono is done, it look marvelous. I didn't hear anything funky from the PWM for the fans either, but I also have the M2 mounted to the rear cover and all the noise making stuff is a foot away. The trans is in the open and I heard nothing with my ear and inch from the speaker.
Now it's on to the second mono and finish off the daughters.
After that, might attack the Honey Badger, just so I have some muscle.
Old 29th June 2020, 12:04 PM   #3248
Default connectors for the daughterboards
I got the prices for the connectors from the manufacturer today.
the socket costs 1,20 per piece
the plug 1,00 per piece
If someone is interested, I can send the connectors.
Shipping costs will of course be added
Old 30th June 2020, 07:39 PM   #3249
grataku is offline grataku  United States
Current status: M2x boards stuffed and in their final resting place (unless the thing sounds really bad).
I made a sloppy frankenstein Ishikawa with stuff I had around (not MJ approved). I am going to test this out first. I am waiting for Tucson parts OPA604, I think I will go with that in the end.
I had some nylon standoff for the mainboard and some brass ones I machined back in the day for the add-on card. Bought the Al ones but did not have M3 screws.
This is an enclosure I made circa 2006 overbuilt to hell. I think it should be able to handle 160W dissipation.
I am still debating around the PS ideas, now that the universal PS is back in stock I have some other options to play with.
I may trade off the increase voltage from the butta' board (SLB) rectification, and burn that off with a higher R of the CRC and forgo the capacitance multiplier at least during initial testing.
Old 30th June 2020, 07:43 PM   #3250
Freedom or Death
Dude that thing is a tank!
The diyAudio First Watt M2xHide this!Advertise here!
What make and model are the original drivers in Wilson Watt&Puppy 7 (WATT) aguiarrj Multi-Way 17 24th June 2017 10:39 PM
2.3 watt x 4 or 5 watt x2 SET amplifier using DECWARE Zkit1 and Zkit4 schematics Redwolf92 Tubes / Valves 12 29th October 2014 10:19 PM
diyaudio moderator vs diyaudio member Leolabs Everything Else 6 18th June 2006 08:19 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
