The diyAudio First Watt M2x
Old 14th May 2019, 09:32 PM   #1851
MEPER is offline MEPER  Denmark
Does an explanation of the schematic in details exist somewhere like a Burning Amp video?
There is some info at Firstwatt but it is very high level?
E.g. diode D1, D2, D3.....this construction looks a bit asymmetrical (everything else looks symmetrical)?
There is also a kind of local feedback from output back to input of mosfets?
Then there is the special optical bias with the two 1.2V voltage references.
Maybe I will find out slowly bit after bit...….
Old 14th May 2019, 10:07 PM   #1852
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Not in this thread, no. The earlier threads about the First Watt product called "M2" (M2x minus the daughter board options) might contain what you want:
GB Pass M2 Clone Boards with 120mm UMS spacing by Tea-Bag
Official M2 schematic
I don't know of a YouTube video about the inner workings of the M2.
It may help to remember that First Watt sold a bunch of M2s to paying customers for pretty big bucks (like $4000 per amp). It got good reviews in the audio press. Then when Nelson Pass decided to stop selling it, he published the schematic here so that DIYers could make themselves a copy if they wanted to. He might not have felt any urgency to "explain" the amp since (a) we already know it sounds great, nobody disputes this; (b) here is the secret schematic that makes it sound great; (c) if you want an amp that sounds like the M2, do this.
_
Old 15th May 2019, 05:33 AM   #1853
Ok.....thank you! I will read it in details…….
Old 15th May 2019, 05:03 PM   #1854
How many hours of work from idea to a final prototype?
$4000 is not that much. Even at DIY if you build a solid power supply and get a nice chassis from HiFi2000 etc. the first $1000 is spend easily.
Old 15th May 2019, 08:00 PM   #1855
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
FW amps are cheap
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 16th May 2019, 01:57 AM   #1856
elwood625 is offline elwood625  United States
Marketing people call it Value Priced. I'm building one and with the diyAUDIO store PC boards, 4U enclosure and parts bought from DigiKey and Mouser for 5 of the six daughter boards, less than $700. After I add bling, just under $1000 and will look good enough for me to be proud of the build.
When I'm done, all I have to do is remove the top cover, loosen/tighten 8 little nuts, and I can turn it into one of 5 different sounding amps including the original M2.
I call it a bargain. The hardest part is finding a 37K resistor
Old 16th May 2019, 02:24 AM   #1857
KevinHeem is offline KevinHeem  United States
KevinHeem's Avatar
How about a 27K and 10K in series?
Old 16th May 2019, 02:50 AM   #1858
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
That value need not be exact and 36.5K and 37.4K are readily available.
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 16th May 2019, 03:21 AM   #1859
Perhaps your personal circuit designer might tell you whether any of these are acceptable: (LINK)
Old 16th May 2019, 04:47 AM   #1860
I forgot to order the 37k but had some 39k...…..which I used together with the 20k pots. I feel confident that this gives enough room for offset adjustment. The boards just looks a bit "messy" now as one resistor is a "normal" Vishay with color bands and all the others are the brown Vishay Dale RN55......will see if I can live with that :-)
The diyAudio First Watt M2xHide this!Advertise here!
What make and model are the original drivers in Wilson Watt&Puppy 7 (WATT) aguiarrj Multi-Way 17 24th June 2017 10:39 PM
2.3 watt x 4 or 5 watt x2 SET amplifier using DECWARE Zkit1 and Zkit4 schematics Redwolf92 Tubes / Valves 12 29th October 2014 10:19 PM
diyaudio moderator vs diyaudio member Leolabs Everything Else 6 18th June 2006 08:19 AM
Copyright ©1999-2019 diyAudio
