The diyAudio First Watt M2x
Joined 2011
Wow, sorry to hear that you find "maybe they will sound different, maybe they won't" to be relatively aggressive. I really AM interested to find out what others think about the sound of the M2x when the five different input stages are installed. Wouldn't it be extremely cool to discover that one of the (gasp!) integrated circuit input stages, sounds better to you than the original Nelson Pass input stage using discrete JFETs? On the other hand wouldn't it be fascinating, to find out that you don't hear any difference between several of the IPSs, despite their wild dissimilarity? I myself find it exhilarating, in either case.
I offer my best wishes for huge success with your M2x amplifier build!
6L6
Moderator
Joined 2010
I'll have to apologize for Mark, he sometimes comes across in text as kinda snarky, but for real is one of the nicest, warmest, smartest and friendliest guys I know. Tone is pretty hard to type, and can come across differently than intended.
Anyway, the point Mark was trying to make isn't that all solid state sounds alike, I don't think anybody is going to argue that, but rather if the sonics of the transformer/autoformer is going to hide any differences that the various input stages impart. I haven't yet had a chance to compare anything even though I do have a few of the input built. I am genuinely interested in what people think as they listen to the different topologies.
6L6 doesn't have to apologize at all.
People like Mark, who make such considerable donations of their time and expertise for the benefit of the multitude should be afforded much consideration and leeway when interpreting their posting.
On the other hand my beard needs to get significantly longer before I fully understand what ZM posts.
:eek:)
Reactions: 1 user
Joined 2011
And 6L6 & I have each made a prediction about what most M2x listeners will say when asked, "Which one sounds best, to you?" . Predictions which we may or may not reveal (depending on how wrong we were), in a few months after people have had a chance to build and listen to their M2x.
edit- predictions based only upon studying the schematics and interviewing the designer. Neither of us "peeked" by listening to all five before predicting.
6L6 & MJ,
I am greatly looking forward to building each and every iteration starting with the Ishikawa as a reference point. Thanks again. I don’t anticipate the Edcor autoformer to be in stock at the diyaudio store anytime soon (although I recall that Mr.Pass was going to forward a stash he had), so I might as well order since Edcor has such long wait times.
Thanks again for providing us with 6 different varieties of amplifier for the price of one!
Anand.
Got an email stating mine are shipping out today and I ordered these on the 16th. If anyone else is needing to get these, i'd order them soon just cause they're shipping them out fast. No telling how long this will last
Ordered my Edcors Saturday 5/19 and they shipped today 5/23. Speedy! Was expecting weeks, not days. Also, PCBs received and look really great.
BK
Joined 2011
Tucson has the 2nd fewest parts to order, and to solder, and to avoid screwing up.
Ishikawa has even fewer, if you are somehow able to get the Toshiba or Linear Audio JFETs.
The lowest distortion opamp IC in the entire world, fits just fine on Tucson. It uses the SMD option. 6L6 and I have both soldered that one onto a couple Tucson boards. We're ready.
BK
Edcor transformers shipped two days after order date.
bk856er & woofertester,
Thanks. Just ordered the Edcor 600:15k (1:5 step up) autoformers.
Best,
Anand.
Assuming the production boards fit in a 2U 300mm long minidissipante case...
Using two Meanwell 24V SMPS, you could run a couple of Juma CapX mounted on the inside of the back of the case to drop the supply rails to ~19V (If necessary add heatsinks on the rear of the case. This results in 50W per channel dissipation at ~1.3A idle current. It should all work in a 300mm deep version of the ACA...
Am I missing anything?
