The diyAudio First Watt M2x
Old 13th December 2018, 05:40 PM   #1141
PH104 is offline PH104  United States
PH104's Avatar
This is a nice reference for semiconductor mounting - this looks like a revised version of an old paper from Motorola:
https://www.nxp.com/files-static/rf_...ote/AN1040.pdf
Phil
Old 13th December 2018, 10:06 PM   #1142
Itsmee is offline Itsmee  England
Itsmee's Avatar
Originally Posted by xrk971 View Post
...have you thought about how you would cut a hole in one?...
Don't need one, using a thick clamping bar will do the job nicely.
Old Yesterday, 08:55 AM   #1143
marconi118 is offline marconi118  Germany
where to find the compression conical washer?
Old Yesterday, 06:04 PM   #1144
chede is offline chede  Germany
... fascinated by amps
chede's Avatar
Look for "Tellerfedern" / "Belleville Washers" at your favourite nuts & bolts supplier ... a Google search returned numerous online shops in Germany.
Best regards,
Claas
Old Yesterday, 11:28 PM   #1145
Sesquipedalio is offline Sesquipedalio
Hi - I have a question on the RV1 orientation: I see a pins 1, 2 & 3 marked on the resistor and on the PCB, a square solder point and two circular ones. Some resources say orientation does not matter, while some diagrams indicate it does. I do not see anything on the schematic or in the forums which tells me which is true. Is there a direction required for correct installation? Thank you all!
Old Yesterday, 11:53 PM   #1146
tsmith1315 is offline tsmith1315  United States
tsmith1315's Avatar
Generally, the odd pad on a component is pin#1. Look at page 1 of this thread, post# 2, first picture for a helpful image.
Tim
Old Today, 12:12 AM   #1147
6L6 is offline 6L6  United States
6L6's Avatar
RV1 doesn't matter how it's inserted in the PCB.
Since you will only adjust it when you are measuring something, you'll merely turn the pot the direction that gets the required result.
Old Today, 06:24 PM   #1148
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Progress on verifying the Melbourne SMT version.
XRKaudio https://www.etsy.com/shop/XRKAudio
The diyAudio First Watt M2xHide this!Advertise here!
What make and model are the original drivers in Wilson Watt&Puppy 7 (WATT) aguiarrj Multi-Way 17 24th June 2017 11:39 PM
2.3 watt x 4 or 5 watt x2 SET amplifier using DECWARE Zkit1 and Zkit4 schematics Redwolf92 Tubes / Valves 12 29th October 2014 11:19 PM
diyaudio moderator vs diyaudio member Leolabs Everything Else 6 18th June 2006 09:19 AM
