The diyAudio First Watt M2x
Old Today, 05:45 PM   #1121
nicoch58 is offline nicoch58  Europe
it is
Old Today, 06:06 PM   #1122
MEPER is online now MEPER  Denmark
How does this type of amp behave if you use a rail fuse for +24V and -24V and one of the rail fuses burns? …...will the output go either +24V or -24V?
Is some kind of speaker protection needed in this case?
Old Today, 06:13 PM   #1123
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Serious reply, not joking:
Try it! Connect dummy 8 ohm load resistors to the outputs, connect shorting plugs to the input, then use insulated plastic pliers to quickly yank out one of the rail fuses. Measure what happens. You may want to enlist a couple of friends to take cell phone videos of the measuring instruments (DVMs, oscilloscopes, whatever) for two or three minutes after the fuse pull.
Second reply, also not joking:
Have a look over in the other, older, thread started by Nelson Pass in 2015. Maybe this experiment has already been performed and results already discussed.
Official M2 schematic
Thanks to the presence of coupling capacitor C2 on the amplifier main board, the input stage plays no role in the amplifier's behavior when a rail fuse blows. It'll do the same thing no matter which daughter card is installed. It'll do the same thing even if NO daughter card is installed.
Old Today, 06:27 PM   #1124
Thank you!
I will have a closer look at the original thread and see if I can find the result of the experiment. But I think I can read "between the lines" that nothing bad happens at the output. So no need for a relay at the output and some smart way to cut if a rail fuse burns…..I am just in a state where I prepare the built. Not started yet…...
The diyAudio First Watt M2xHide this!Advertise here!
What make and model are the original drivers in Wilson Watt&Puppy 7 (WATT) aguiarrj Multi-Way 17 24th June 2017 11:39 PM
2.3 watt x 4 or 5 watt x2 SET amplifier using DECWARE Zkit1 and Zkit4 schematics Redwolf92 Tubes / Valves 12 29th October 2014 11:19 PM
diyaudio moderator vs diyaudio member Leolabs Everything Else 6 18th June 2006 09:19 AM
