Hello everyone,
I am on the way building Aleph5, but I face the problem on the PSU DC voltage. I have arrange the PSU as the picture.
The transformer secondary voltage is 2X25VAC 750VA, and the actual value I measure was 27 VAC.
After power up, it work OK, but I only get 32V maximum DC output with no load. I think it suppose to be at least 34V? what is possible to go wrong? any idea?
Thank you
Thank you
Is your line input voltage within spec for the transformer?
Yes, it was a little bit over 220VAC.
That depends on your calculation... did you take diode losses and voltage regulation of your transformer into account ? A 750VA toroid should have around 4-6% regulation , at least that's what I have seen...
I am not really sure, but I use 27VAC that I actually measured from the secondary side.
Mutiply by 1.414 will get 38VDC. I take out 1.5V for full wave rectifier then I should get more than 35VDC with out load?
Yes, try loading the DC outputs with 1A or so and see what happens.
I have noticed that a transformer may read a little high without any load so I might be tempted to at least put some small load on the secondary even a 25 to 100 watt light bulb. Another thing it's easy to overlook that you lose about 2v across the bridge rectifier so DC out is AC X 1.41 - voltage lost across the rectifier .
Is too much capacity of psu cap make the voltage lower than calculation? I only get 31.xxx. VDC. No load.
It's the opposite. Not enough capacitance will give lower voltage. Perhaps your capacitors are not functioning properly or their connections are not working properly.
I have loaded it with 2 channel of over bias aleph5. Total current draw was 6 A
The voltage before R was not change and same as the voltage measureed when no load, Just only the output dc voltage which droped by 1 V from CRC filter.
It seem to be work normally except the DC voltage after rectifier which was quite low.
What AC voltage across the secondaries do you measure when the DC outputs are loaded?
If that is normal, maybe the wrong value of resistors for the CRC filters.
Only if your mains voltage is sinusoidal. The 27VAC is an RMS measurement/approximation depending on how your multimeter works.I am not really sure, but I use 27VAC that I actually measured from the secondary side.
I have not measured the AC voltage because all connector was covered by heat shrink tube.
But I have measured the DC voltage before resistors and it was around 32VDC both load and no load. And voltage drop across the resisters was as I expected.
In my understanding, voltage was same for no load and load mean the transformer regulation is not bad. But I don't know why I get lower voltage after rectify.
Interesting point. Is that possible for too distorted wave form in the power line to effect quite a lot.
It's possible. If you measure 32Vdc then the peak AC is about 33.4V and the RMS of a perfect sinewave would be about 24V. You are measuring 27V or about 10% too high. It could be multimeter accuracy and/or a distorted mains waveform.Interesting point. Is that possible for too distorted wave form in the power line to effect quite a lot.
Large appliances can distort the mains and sometimes you can hear their effect when your transformer makes buzzing sounds.
Is this low voltage effect to the power amp, aleph 5 need dual 35 v supply? Should I measure the power line wave form?
Permit the question: Do you need more voltage or are you just wondering about the value ?
For me your PSU is fine, the load pretty heavy, so it's expected for the rails to sag a little.
I'd say, just keep on going....
Yes, I just only worry about the voltage. It seem to be too low for aleph5? At around 32v.
nothing to worry about , everything is right in measurement tolerances
Thank you, I keep on going
- Need help for PSU voltage
