..nothing better than having right setup in your own room..
High End 2016 Munich: Tune Audio Anima 3-way horn loudspeakers / Rockna Audio on Vimeo
The most Sissy mono blocks on the show.
Millionnaires use them in the 250 square meters kitchens
Rock for the regular bikers. Guess sound capture by are a lot directive
Trafomatic Audio Pandora - at the High End 2018 Munich Show! on Vimeo
Here's a short SIT 3 demo since there aren't many online. It's the best sounding SIT 3 demo on Youtube. Speakers are 4 ohm Denso 4x6" in custom OB's. The Denso 6x9"s weren't as revealing. The 4x6"s play better with the SIT than the Buchardts or Infinitys maybe because of complex crossovers? All the junk everywhere is for acoustic treatment.
First Watt SIT 3 with Eclipse 8463A (denso) in custom enclosures - YouTube
I'm a fan. I have limited experience though. My other DAC is a Topping dx7s which uses ESS ES9038 chips. Adcom sounds more liquid and no less revealing.
I'm biased by the fact the ADCOM is made in the US and the relay makes a satisfying clink when the signal locks. If you've ever shut the door of an old BMW you can hear the quality. I can hear the quality of the ADCOM
- SIT-3
