SIT-3
The one and only
Joined 2001
Just a tad under 1 cu ft. Mario Yrun made them.
:cheers:
While contemplating the simplified diagram of the circuit in the SIT 3 Owners Manual, it made me wonder if it would be possible to adapt the concept to accommodate all of the left over Sony 2SJ28 VFETs out there.
I realize we are talking VFET and not SIT, but would it be possible to find an N channel Mosfet whose Gate voltage is the mirror image of the 2SJ28 and then reverse the voltage to accomplish a similar result?
I'm sure I'm showing my utter ignorance of circuits, but I thought I'd ask anyway. :eek:
Joined 2000
VFET and SIT are the same.
http://www.firstwatt.com/pdf/art_sit_intro.pdf
The problem is finding pairs of mosfets and vfets with matching Vgs, like you said.
It's been shown before that reversing the polarity in the circuit when using a P-ch device works. But in this case, wouldn't it be a positive supply? The SIT-3 uses a negative supply. Let me check...it does. Shows it right in the SIT-3 manual.
Official Court Jester
Joined 2003
ground is state of mind
SIT-3 uses positive supply , but mind is easily fooled (which I'm confirming several times per day)
:clown:
Joined 2000
If the lid of the SIT-3 is vented, then yes. Think I read- at least 3" clearance between components.
Surprising amount of heat is generated inside Class A amps; not just from the heat sinks. Heat from the SIT-3 could also heat up the chassis of the HP1.
Good looking couple though. Congrats on the marriage of the two! :)
While contemplating the simplified diagram of the circuit in the SIT 3 Owners Manual, it made me wonder if it would be possible to adapt the concept to accommodate all of the leftover Sony 2SJ28 VFETs out there.
Hi WBS, that is what I plan to do in the future. I have some quantity of 2SK28s. We can parallel two 2SJ28s. :):)
I am not so knowledged but I think 2SJ28 + IRF240 will do the same work as 2SK82 + IRF9240. If not someone please correct me.
