Preamp with LS Jfets
Old 24th April 2018, 06:48 PM   #61
qwertyl is offline qwertyl  United Kingdom
Originally Posted by juma View Post
There are very rare situations where pot at the preamp's output isn't a bad idea and this is not one of them.
Many had the same idea before (do something differently from the mainstream, at any cost) but in the end it boils down to this (post #500) :
LSK pre - BAF 2013
I see that you are primarily interested to get a confirmation for your idea so go ahead, it's easy to try both (pot at the input and pot at the output) and keep what you like better.
Not at all, just considering various options. Thanks for your advice - pot at the input it is then
Old 25th April 2018, 01:42 PM   #62
lineup is offline lineup  Sweden
lineup's Avatar
Originally Posted by Nelson Pass View Post
This was presented at BAF four years ago, and I thought I had written
it up, but if I did I can't find it.
Here's the graphics of a nice line level gain stage which has no loop feedback.
Great circuit, Nelson!
That it uses all FETs from LS is an additional plus.
I wonder what is the approximate Vgain of your circuit in first post?
Can one change the gain a bit .. and if so, how?
lineup
Old 26th April 2018, 08:53 PM   #63
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
The response graph shows the gain at 15.5 dB.
You can adjust the values of R3 and R6 over a fairly wide range.
As you increase R3 the gain goes down and vice versa.
As you increase R6 the gain goes up and vice versa.
Old 27th April 2018, 08:00 AM   #64
lineup's Avatar
Thanks Nelson.
Anybody knows where one can buy those transistors?
Is the only option at BIFET, JFET, INTERFET, Diodes, Transistors, DMOS, MOSFET homepage?
lineup
Old 27th April 2018, 01:46 PM   #65
Telstar is offline Telstar  Italy
There should be retailers that carries them in EU.
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
Old 29th April 2018, 07:48 AM   #66
lineup's Avatar
okay, that is fine
I keep on searching
lineup
Old 11th June 2019, 09:01 PM   #67
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Question Voltages
I have another bonehead question. I watched the BAF 2013 video several times over the years since released, but still baffled by the voltage requirements.
Reference schematic for LSK Preamp in first post.
The circuit can run off +/-45v, and the input and cascoded jfets need 30mA.
However, when describing the jfet output buffer to lower output impedance, There's talk about the jfets can only handle around 25v.
Why can the input and cascade jfets handle 45v and the buffer cannot?
I know R4 and R5 provide 30mA
Is there a voltage drop provided by the 1k R4 & R5 that lowers the rail voltage?
Does the jfet themselves and R3 come into play in lowering/adjusting the voltage to another level?
Kirchhoff's Law come into play? All the voltage drops must equal 45v?
I build, therefore I am.
Old 11th June 2019, 09:09 PM   #68
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
see 18V marked ?
these JFets (in post #1) are seeing 18V from D-S
include buffer stage , cascode it regularly to 12-15-18V rails , and you're good
aha ...... I forgot to say - second half JFets - they're having gates clamped to 18V ; source is looking at 1K resistors and they will fight to death to keep source voltage somewhere near 18V too
think how JFet is biased and you'll realize what "somewhere" means
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 11th June 2019, 11:41 PM   #69
vdi_nenna's Avatar
Man, this stuff is confusing. More power to you guys.
Preamp with LS JfetsHide this!Advertise here!
Balance control-where in the preamp chain should it go? rif Solid State 3 20th July 2015 05:08 AM
FS: Pass DIY B1 buffer preamp PCB w/ 4 matched JFETs Oscillate Swap Meet 1 10th March 2015 06:13 AM
Line Level Preamp, Using JFETs, in a can. BowtoEd Analog Line Level 8 27th April 2012 11:12 AM
jfets for preamp kzeprf22 Solid State 14 21st November 2008 02:35 PM
Looking for balance preamp using NJM5565 aeon845 Solid State 3 26th September 2004 02:07 PM
Copyright ©1999-2019 diyAudio
