"WHAMMY" Pass DIY headphone amp guide
Old 23rd January 2018, 05:23 PM   #11
kamis is offline kamis  Serbia
Why balanced microphone cable at the input? Left and right channel wires are close to each other, which is bad for crosstalk.
Old 24th January 2018, 03:56 AM   #12
6L6 is offline 6L6  United States
6L6's Avatar
There are all kinds of wire to try!
Old 24th January 2018, 10:11 PM   #13
Ultrasparc is offline Ultrasparc  Canada
Are boards for this going to be available on the diyAudio store?
Old 24th January 2018, 11:20 PM   #14
6L6's Avatar
Yes, we're working on that now.
Old 24th January 2018, 11:29 PM   #15
Excellent. Thank you for the quick response .
Old 5th February 2018, 10:15 AM   #16
stijn001 is offline stijn001  Netherlands
stijn001's Avatar
Originally Posted by 6L6 View Post
Thanks. Looking forward to this build.
Old 10th February 2018, 03:29 AM   #17
ve6sdw is offline ve6sdw  Canada
I am trying to track down the heat sinks that are used for this headphone amp.
Does some one have a part number and suppler?
Old 10th February 2018, 05:03 AM   #18
6L6's Avatar
I think these are the right part - 531102B02500G Aavid Thermalloy | Mouser
1" pin spacing, and choose height to fit in your enclosure of choice
Old 10th February 2018, 08:42 AM   #19
silasmellor is offline silasmellor  Denmark
In the process of building this. I have an earlier rev board without the 2k2 resistors between the inputs and the pot. How important are these? I have the pot on a separate board so I can just insert them if that's better. Can other values be used?
Old 10th February 2018, 10:29 AM   #20
Ah sorry, I had not looked properly at the schematic. So i suppose i can just add them if i need to lower the gain a tad.
"WHAMMY" Pass DIY headphone amp guideHide this!Advertise here!
FS: Nelson Pass "CSX1/2" "Buffered F6" Front End PCBs luvdunhill Swap Meet 7 10th December 2016 03:03 PM
Small midrange boost with conical "guide" suggestions? Phenoholic Anonymus Multi-Way 11 1st December 2014 01:00 PM
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 04:35 PM
The "Dummies' Guide to getting parts/assembling CarlosFM's chipamp" Spasticteapot Chip Amps 19 18th March 2006 06:17 AM
