"WHAMMY" Pass DIY headphone amp guide
"WHAMMY" Pass DIY headphone amp guide Please consider donating to help us continue to serve you.
Old 20th January 2020, 09:58 PM   #1921
passive420 is offline passive420  United Kingdom
Originally Posted by Gregje View Post
Have you compared Whammy without/with the xfeed? People seem to like these xfeeds.
Hey Greg, yes mate this is the second time building the Whammy and on this board I spent a good few hours with a plain 20K pot before trying the Xfeed with a 10K Alps.
Now the Xfeed is very subtle, don't worry it doesn't add or subtract from the music but seems to place the music in the front and centre but somehow keeping depth. I guess it sounds more accurate and integrated inside your head and it seems to reduce fatigue somewhat, I can listen for hours or as long as I can stand the phones on my head.
So I would say the XFeed works very well, the Danyuk passive version here (you'll be getting soon!) is the most simple version is seems, follow Patricks component values and it will work in most situations but you can tailor the crossfeed point to suit. Interestingly the Xen motherboard has very different Xfeed component values for some reason.
Zen Mod - fixed the pot squelch and noise, I hadn't screwed the front plate properly! The pot was not connected to the chassis earth! Once this was done, no problems.
So running with 1K for R39/40 inputs, 10K for R4/R8 and no compensation caps yet, might try some 47pF.
While I was under the hood, I added some extra 0.1uf MKP decoupling caps to C1/C3 and C9/C28. Everything sounds very good.
My favorite op-amps it seems are two LT1028. Slightly better maybe than OPA627BM.
Old 20th January 2020, 10:17 PM   #1922
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old Yesterday, 09:43 AM   #1923
Gregje is offline Gregje  United Kingdom
Yes, mine is already in transit. I am looking forward to another build.
Old Yesterday, 01:58 PM   #1924
AllanMarcus is offline AllanMarcus  United States
Originally Posted by rich1051414 View Post
Theoretically, this would increase the capacitance from all that extra socketing wouldn't it?
I doubt it is audible, but I would feel compelled to have a properly soldered riser if I did something like that.
Also, distance is a very important thing regarding the bypass capacitor for the op amp power rail, so the distance as well may effect things.
Like I said, I doubt it would be audible, but both things are things you typically try to avoid with op amps.
If I were to use the Burson as the permanent opamp, I would not stack the sockets like that; I would reconfigure the caps on either side to allow for more opamp space. It's a temporary solution so that I could use the Bursons.
Mostly a headphone guy. See my DIY site at https://sites.google.com/marcusfamil.../diynotes/home
Old Yesterday, 07:24 PM   #1925
avdesignguru is offline avdesignguru  United States
avdesignguru's Avatar
Default OPA2107AU vs OPA1612AID
Finally tested an OPA2107AU which requires a SMD to DIP adapter. Very clear and precise with a good sound stage. A bit clinical, cold and unexciting. Not harsh. Some may like it but I prefer the OPA1612AID, particularly on Sennheiser HD650 headphones. I'll be sticking with the OPA1612AID as an upgrade to the OPA2134PA.
The OPA1612AID sounds wonderful on all my headphones, HiFi Man HE400i, Sennheiser HD650 and Masters and Dynamic MH40.
Builds: Papa's B1, B1-Korg, F6, M2x, ACN; Wayne C's Whammy, Pearl II; Mark J's T2; Mike R's MoFo; Pete M's NuTube Buffer, NuHybrid, NuClassD; John B's Aikido;
Old Yesterday, 09:58 PM   #1926
Martigane is online now Martigane  Belgium
I compared the following op amps, and so far OPA2107AU is the very best. Using hd58x modded:
Opa2107
Lm833n
Opa1642
Opa2156
Lme49720NA
And some waiting to be tested:
Ad8599Arz
Lme49860
Burson v6 classic
Burson v6 vivid
Then i ll note my subjective observations and only then measure few key test with apx555.. will be fun
"WHAMMY" Pass DIY headphone amp guideHide this!Advertise here!
FS: Nelson Pass "CSX1/2" "Buffered F6" Front End PCBs luvdunhill Swap Meet 9 19th October 2019 07:47 PM
Small midrange boost with conical "guide" suggestions? Phenoholic Anonymus Multi-Way 11 1st December 2014 01:00 PM
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 04:35 PM
The "Dummies' Guide to getting parts/assembling CarlosFM's chipamp" Spasticteapot Chip Amps 19 18th March 2006 06:17 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
