"WHAMMY" Pass DIY headphone amp guide
"WHAMMY" Pass DIY headphone amp guide Please consider donating to help us continue to serve you.
Old 13th January 2020, 08:59 PM   #1891
wayne is offline wayne  United States
Auburn
wayne's Avatar
Here is a ground isolation circuit. The most important thing is to get a good hard earth ground to your chassis like Jim (6L6) stated. Remember anodizing is insulating so scrape and check with a meter. This circuit will help prevent ground loops yet carry fault currents.
wizards assistant
Old 13th January 2020, 09:16 PM   #1892
MEPER is offline MEPER  Denmark
MEPER's Avatar
Do you recommend that jack connector is isolated from chassis and then only make the above analog gnd to chassis (assuming that GndEarth is chassis)?
Old 13th January 2020, 09:19 PM   #1893
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
Yeah
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 13th January 2020, 09:43 PM   #1894
MEPER's Avatar
Ok.....but the jack connector in the official kit is not isolated and signal gnd will get chassis connection via jack connector. Probably the reason why only a small cap is recommend from input signal gnd to chassis/earth.
Then something like a Neutrik jack connector should be used. I just checked that it has isolated signal gnd.
Old 14th January 2020, 07:14 AM   #1895
AudioSan is online now AudioSan  Norway
Allmost all RCA jack's on the market comes with isolation washers in nylon (red and white, or red and black). Also the ones in this kit if the store image is correct.
Old 14th January 2020, 09:14 AM   #1896
MEPER's Avatar
Yes, but not the jack connector for the headphone. Via this connector signal gnd will get chassis connection. It works fine in my setup with no hum ect. as this it may only gnd to chassis connection. I have no earth in outlets so nothing to "polute" signal gnd via chassis. So a direct gnd to chassis works.
Old 14th January 2020, 01:02 PM   #1897
6L6 is offline 6L6  United States
6L6's Avatar
The REAN NYS212 is isolated from chassis, has solder lugs and is switching. It’s a very nice jack. NYS212 REAN / Neutrik | Mouser
Old 14th January 2020, 01:33 PM   #1898
i got my headphone jack's from e-bay. plastic housing and switching type.
Old 15th January 2020, 01:59 AM   #1899
Pierce911 is offline Pierce911  United States
I'm getting some funky numbers coming out of my opamp. The measured voltages are as follows..
(1) .43 V (8) 16.63 V
(2) 14.8 mV (7) -7.08 V
(3) 13.8 mV (6) 15.2 mV
(4) -16.61 V (5) 13.9 mV
What could be causing this 2OUT (pin7) voltage? I've switched out the socket and tried different opamps that I know are working on a second Whammy that I put together.
As a reference, my other stock Whammy (which is working) measures as follows...
(1) .17 V (8) 16.59 V
(2) 14.8 mV (7) .15 V
(4) -16.66 V (5) 13.9 mV
Old 15th January 2020, 06:41 AM   #1900
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
solder second one better
or find missed component
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
"WHAMMY" Pass DIY headphone amp guideHide this!Advertise here!
FS: Nelson Pass "CSX1/2" "Buffered F6" Front End PCBs luvdunhill Swap Meet 9 19th October 2019 07:47 PM
Small midrange boost with conical "guide" suggestions? Phenoholic Anonymus Multi-Way 11 1st December 2014 01:00 PM
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 04:35 PM
The "Dummies' Guide to getting parts/assembling CarlosFM's chipamp" Spasticteapot Chip Amps 19 18th March 2006 06:17 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
