"WHAMMY" Pass DIY headphone amp guide
Old 16th May 2019, 08:34 PM   #1411
rich1051414 is offline rich1051414
Originally Posted by bk856er View Post
Is there a favored Mogami mic cable for internal Whammy wiring? Mogami PN would be helpful - several types are possible!
BK
I had an old XLR to mic cable(which I never use) that I cut. Seems to be what most people are using(or similar).
Old 17th May 2019, 02:49 AM   #1412
bk856er is offline bk856er  United States
bk856er's Avatar
Originally Posted by Gricko View Post
I use 2496
I can't find a match to that PN.
Looks like W2791 or W2549 or W2944 would be good choices (bulk/markertek), the first two are mic cable and the third console cable.
BK
Old 17th May 2019, 03:37 AM   #1413
6L6 is offline 6L6  United States
6L6's Avatar
Basically any of the Mic cable (2-conductor plus shield) will work perfectly for the whammy -
W2552 Mogami W2552 Microphone Cable (Black)
W2549 Mogami W2549 Long Run Mic Cable (Blue)
W2697. Mogami W2697 Miniature Balanced Mic Cable (By the Foot)
If you order from there, spend 5 bucks and do yourself a favor and get 20ft of 2381 as well, it's a small flexible coax that makes great wiring to/from RCA jacks and such. My absolute favorite for wiring RCAs to PCBs. Mogami W2381 Black Coaxial Cable, 50 Ohm (By the Foot)
Old Yesterday, 03:14 AM   #1414
Originally Posted by 6L6 View Post
You don't want a super fast opamp in whammy, (or honestly, in most audio devices) there's absolutely no need and it has the possibility of making it unstable and/or oscillating. If you have a slew rate thats 10 times faster than the absolute fastest music signal theoretically possible, that will be great, and still fairly slow when compared to video signals ad faster things. I.E., super fast isn't important, and can be detrimental.
Broadly speaking, a type that the manufacturer labels suitable for audio will work beautifully.
I really like the LM833 in this circuit as well.
So, for science, I tried my hardest to push the whammy into oscillation, but I failed xD
I grabbed a couple random video op-amps, and they didn't sound the best, but they also wouldn't push the opamp into oscillation.
I then said 'screw it', and grabbed the op amp with the highest slew rate I have on hand, the AD812ANZ, which has a 1600 V/ms Slew. For comparison, the LM833 has a 7 v/ms slow, and the LM4562 has a 20 v/ms slew.
Still no oscillation... and it actually sounds amazing. I gave up. That was not the result I was looking for xD
The weird part is I have sent preamps into oscillation before because of what you were talking about, but I would be damned if I could recreate it on the Whammy xD
Old Yesterday, 03:23 AM   #1415
bk856er's Avatar
Thanks, 6L6, for the Mogami tips! Parts now converging for the preamp piece of "project analog source".
BK
Old Today, 03:22 AM   #1416
bk856er's Avatar
I seem to be full of questions lately. Trying to line up a 20k Alps RK271 pot and decipher the not-always-complete mfg part numbers. Seems there are two different audio tapers possible, 15A and 3B. Is one preferred or considered standard?
BK
Old Today, 03:40 AM   #1417
6L6's Avatar
ALPS 20KAX2 20K Ohm Audio Taper Stereo Potentiometer 6mm Shaft
That one.
Old Today, 03:51 AM   #1418
bk856er's Avatar
That takes away all the ambiguity - thx.
BK
"WHAMMY" Pass DIY headphone amp guideHide this!Advertise here!
FS: Nelson Pass "CSX1/2" "Buffered F6" Front End PCBs luvdunhill Swap Meet 8 11th May 2019 01:58 PM
Small midrange boost with conical "guide" suggestions? Phenoholic Anonymus Multi-Way 11 1st December 2014 12:00 PM
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 03:35 PM
The "Dummies' Guide to getting parts/assembling CarlosFM's chipamp" Spasticteapot Chip Amps 19 18th March 2006 05:17 AM
Copyright ©1999-2019 diyAudio
