Replacement For Toshiba 2SK170/2SJ74
Old 29th March 2020, 06:25 AM   #441
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
Jfet's book in public domain https://ia801000.us.archive.org/5/it...plications.pdf
Enjoy
File Type: jpg 3DFAEA14-4455-4FB2-8EE5-5980DB20AAB3.JPG (92.3 KB, 758 views)
class A amplifiers with full range speakers
sings like angels in heaven
Old 29th March 2020, 08:56 AM   #442
Itsmee is offline Itsmee  England
Itsmee's Avatar
Old 5th May 2020, 12:02 PM   #443
DQ828 is offline DQ828  Australia
DQ828's Avatar
Hi
I just need one FET to put in a Tube-I-Zator board I bought some years back and of course the BOM nominates the 2SK170BL!
I'm trying to do this on a budget and I'm not keen on spending money on a bunch of high end rare FETS which I may never use.
This is probably sacrilegous but is there an acceptable substitue that I could just buy from Mouser for a buck or 2?
Old 5th May 2020, 12:42 PM   #444
Mark Johnson is offline Mark Johnson  United States
diyAudio Donor
Mark Johnson's Avatar
Wouldn't the Tube-I-Zator people know the best answer for this?
Old 5th May 2020, 12:53 PM   #445
Soundhappy's Avatar
Originally Posted by DQ828 View Post
..This is probably sacrilegous but is there an acceptable substitue that I could just buy from Mouser for a buck or 2?
J113 ON Semiconductor / Fairchild | Mouser France
Old 5th May 2020, 01:02 PM   #446
Zung is offline Zung  Switzerland
BF256B
It's just a current source in a power supply, adjustable too.
Old 5th May 2020, 01:12 PM   #447
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
As current sources they should be fine. Note, however they have different pin-outs
than the 2sk170 so they won't be drop-in replacements.
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 6th May 2020, 10:05 AM   #448
DQ828's Avatar
Thanks for all of the responses greatly appreciated, my head was spinning trying to look through data sheets, I dont really know one end of a transistor from the other
Old 6th May 2020, 11:15 PM   #449
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Originally Posted by Soundhappy View Post
J113 is good for a lot of things, including carrying signal in the B1 Korg,
but it's not much of a substitute when you are looking for really low
noise, follower output impedance and distortion.
For Korg preamps and H2, they work fine inasmuch as these factors
aren't quite as applicable. The J113's do make decent constant current
sources though, as they are routinely degenerated enough to make
them more neutral.
Old 7th May 2020, 12:43 AM   #450
Soundhappy's Avatar
Mr. Pass thanks for reminding me and kindness
Replacement For Toshiba 2SK170/2SJ74Hide this!Advertise here!
Toshiba 2SK170/2SJ74 FET's and other semis for sale duffears Vendor's Bazaar 63 6th December 2016 01:27 PM
Swapping matched for unmatched Toshiba 2SK170 / 2SJ74 Jfets NicMac Swap Meet 4 30th October 2016 06:16 PM
2SK170 2SJ74 F-5 BOM?????? paul stewart The diyAudio Store 5 19th July 2013 07:04 AM
FS 2sj74 and 2sk170's take 2 :) Woody1911a1 Swap Meet 43 28th August 2011 09:33 PM
2sk170, 2sj74 enzedone Parts 4 21st December 2008 05:38 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
