Replacement For Toshiba 2SK170/2SJ74
Official Court Jester
Joined 2003
it seems someone is taking 2SK2145 as substitute for 2SK170, using case adapter pcb
treating those 2 JFets in one case as one
from 2SK2145 datasheet .......X is type, G is GR current rank, in this case 2.6-6.5mA
doable and effective, but only if taken care of current ranges (GR, BL, V) and appropriate translation between origin and substitute
so, practically translated to BL range of 2SK170, 6.5 to 12mA
Reactions: 2 users
Is there supposed to be something underneath those two areas that almost look like, I hate to say this, solder blobs (first picture)? I also think this cat could use a little less solder on those pins personally, but that’s just my own opinion and you know what they say about that.
