Replacement For Toshiba 2SK170/2SJ74
Old 5th August 2018, 09:08 PM   #211
EUVL is offline EUVL  Europe
IV curves :
xen-audio
Why match :
xen-audio
Patrick
xen-audio.com
Old 5th August 2018, 09:30 PM   #212
MEPER is offline MEPER  Denmark
When Idss is measured at what Vds should that normally be done to get a "standardized" value for Idss? …..a Vds just before break down to get the max Ids?
Some use 9V.....but that is because they use a 9V battery for the measurement?
Old 6th August 2018, 12:00 AM   #213
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Originally Posted by MEPER View Post
When Idss is measured at what Vds should that normally be done to get a "standardized" value for Idss? ..a Vds just before break down to get the max Ids?
It's completely your choice, do it however you please.
Me, I like to get far away from the knee and the linear region. So I prefer to measure well above ~ 4 x |Vpinchoff| which ensures I'm well away from the knee.
For the 2SJ74 in Toshiba's datasheet, that's something well above ~ 3.6 volts. 9 volts is certainly well above 3.6 volts. Naturally, other designers may interpret the data differently, or arrive at a different final preference.
_
Old 6th August 2018, 07:41 AM   #214
Ok....so 9V Vds could be a real operation condition in an amplifier.
Would the curves had looked "nicer" if there was same distance between them so a change in Vgs gave same change in Ids?
I am still at a "FET learning curve" :-)
Old 27th August 2018, 03:45 PM   #215
eddyvb is offline eddyvb  Belgium
On request from RafaPolit
Do you think these are fakes? Reichelt is a big German company.
2SK 170: JFET, N-CH, 40V 20mA, 0,4W, TO-92 bei reichelt elektronik
I think they ship worldwide. Or I could buy a few if you want.
To be sure you must be able to make fet noise measurements?
Old 27th August 2018, 04:08 PM   #216
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
A member received fake 2sj74bl from Reichelt:
That said, the 2sk170 seems to be easier to find, but I would
still suggest caution and test a few samples before ordering in quantity.
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 27th August 2018, 04:12 PM   #217
Zatopek is offline Zatopek  Germany
Zatopek's Avatar
Default Procurement of 2SK170/2SJ74 pairs
I have purchased the 2SK170/2SJ74 from Reichelt and can assure that the once I received DO NOT work as input stage in the BA3!!!
The price of about 4,- was just too attractive but it was impossible to set the biasing of the output MOSFET's at all. Complete failure and hours of frustration wasted!! This was about in April this year and they might have changed their source.
Meanwhile I have purchased matched pairs through NicMac in Milano. These are original Tosh's and of course NicMac has to take more than 4,-. Good message is, that I had biased both channels of my BA3 within about 1hr within the ballpark range you like the bias to be in. Perfect stuff!!
Elektor Crescendo-ScanSpeak d'Appo-F5TV2
Old 27th August 2018, 04:19 PM   #218
NicMac is offline NicMac  Italy
NicMac's Avatar
And @ 3.20 euro a piece, its not really a bargain.
Old 27th August 2018, 05:28 PM   #219
6L6 is offline 6L6  United States
6L6's Avatar
The Reichert 2SJ74 are GR grade and won’t match the BL K170s they are selling.
Old 27th August 2018, 10:07 PM   #220
Skylar88 is offline Skylar88  South Africa
After posting in the ACA thread, I thought that I should mention it here too.
I have ready access to genuine Toshiba 2SK170BL's and would be willing to match and supply if needed. No 2SJ74's unfortunately.
I have built a B1 and ACA with pairs that I matched myself. So far I found pairs with Idss between 6.9mA and 10.0mA. If there is a need for quads, I can probably do that too.
Replacement For Toshiba 2SK170/2SJ74Hide this!Advertise here!
Toshiba 2SK170/2SJ74 FET's and other semis for sale duffears Vendor's Bazaar 63 6th December 2016 02:27 PM
Swapping matched for unmatched Toshiba 2SK170 / 2SJ74 Jfets NicMac Swap Meet 4 30th October 2016 07:16 PM
2SK170 2SJ74 F-5 BOM?????? paul stewart The diyAudio Store 5 19th July 2013 08:04 AM
FS 2sj74 and 2sk170's take 2 :) Woody1911a1 Swap Meet 43 28th August 2011 10:33 PM
2sk170, 2sj74 enzedone Parts 4 21st December 2008 06:38 AM
Copyright ©1999-2019 diyAudio
