F5-style pre
F5-style pre
Old 19th December 2017, 09:20 AM   #1
Abrandt is offline Abrandt  Sweden
Default F5-style pre
Hello guys!
Some pictures from my latest project.
I needed a preamp with some gain to drive my ZV9. The B1 I used had not the juice to drive the amp to full output with some programmaterial.
I wanted a solid state amp and I had already made the powersupplie so the +-15V was in place. I tryed some other preampideas from the internet but I was not fully satisfied. Then I got the idea to do something F5-like. And it worked out rather well I think. Please give me some feedback. More pictures if you want.
Merry christmas from Sweden, Abrandt
Old 19th December 2017, 10:18 AM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5-style pre
YouTube
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 19th December 2017, 11:11 AM   #3
EUVL is offline EUVL  Europe
Balanced version :
The F5X Preamp
Patrick
xen-audio.com
Old 19th December 2017, 01:27 PM   #4
indra1 is offline indra1  Indonesia
Hi Abrandt, could you kindly share your reason(s) for your choice to cascode the input jfets and your choice to reference the bases of cascode transistors to supply voltage instead of ground?
Old 19th December 2017, 01:35 PM   #5
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
F5-style pre
Beautiful work! Love the bare wire 3D sculptures to the RCA’s.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 19th December 2017, 05:59 PM   #6
Indra1
The cascod is mostly because I would try to do it and maybe to get a little less distortion. You could absoluteley make a version without them. Your question about the reference voltage, I don't understand. I have to get fixed voltage at about 5 Volt's at the bases. I could done that without the zeners maybe but ??
/Abrandt
Old 19th December 2017, 06:06 PM   #7
He was asking whether you connected the Zeners to Gnd and the resistors to the rails, as it should be.
The other way round was shown in your hand sketch schematics.
Patrick
xen-audio.com
Old 19th December 2017, 06:21 PM   #8
Hi Abrandt, in case you have not done listening comparison, you may want to try 9.1V at the bases of the cascoding transistors by switching the zeners and the 4k7 resistors. I think the jfets will perform a bit better with ~8.5V at the drains.
Old 19th December 2017, 06:35 PM   #9
OK I se now what you mean. Du you think that would make any differens? Are not the voltage fixed at the bases in both cases? And Indra1 do you say that the FET's do a better job with 8V at the drain? / Abrandt
Old 20th December 2017, 12:59 AM   #10
Yes, I think so due to lower Crss and Ciss while IGSX is still quite low.
F5-style preHide this!Advertise here!
Enclosure style east electronics Multi-Way 1 27th November 2015 08:11 PM
Travellining in Style PeteMcK Everything Else 1 6th June 2012 01:29 AM
DIY home etched boards, old style, simple, fast and SMD style destroyer X Solid State 51 11th April 2011 10:07 PM
DNM style urxle Chip Amps 4 10th January 2007 08:25 PM
3 way speaker my style classe Multi-Way 3 16th November 2004 06:39 PM
