Ink and heat transfer?
Old 17th December 2017, 01:49 PM   #1
JeffYoung is offline JeffYoung  Ireland
JeffYoung's Avatar
Default Ink and heat transfer?
I mark the backs of JFETs and MOSFETs with a Sharpie. Do I need to remove this before mounting, or will the ink make no difference?
Old 17th December 2017, 07:34 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
no diff
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 18th December 2017, 05:48 AM   #3
PRR is offline PRR  United States
PRR's Avatar
Put your finger on a hot stove.
Now put Sharpie on another (unburnt) finger and put it on a hot stove.
I suspect you now have two equally burnt fingers. And are sorry you asked.
That's basic $1 Sharpie. Paint-markers can leave sensibly thick marks, and should be scraped off.
Old 18th December 2017, 06:19 AM   #4
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Black Sharpie is special. Other colors are different. Black is graphite pigment based, and binder is very tough - acid resistant so black Sharpie can be used to make traces for PCB etching. When the binder is baked/cooked off, you are left with black color (and presumably carbon residue). Blue/green/red/purple are dyes and binder is not durable as the acid etchant (H2O2/HCl) eats through it, and when baked/cooked - all traces of pigment fly off as VOC vapor. Not that any of this matters for heat transfer when the layer is sub micron thin. But black may pose more of a barrier than other colors if laid on thick.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 18th December 2017, 10:54 AM   #5
JeffYoung's Avatar
It is black, but not very thick.
And I sprayed some Burn-Eze on my two burnt fingers.
Jeff.
Old 18th December 2017, 01:53 PM   #6
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Ink and heat transfer? Send a message via Yahoo to vdi_nenna
One thing to be aware of is, if you tap your own transistor mounting holes in a heat sink, be sure you clean away any tapping fluid or WD40 or whatever fluid used. Don't let it seep back in behind the transistor and heat sink. I'm sure this happened to me once. Doesn't take much. Results are not good.
I build, therefore I am.
Old 18th December 2017, 03:46 PM   #7
JeffYoung's Avatar
He he... you only have to get tapping fluid on the furniture once before you learn that everything goes in the parts washer after machining.
Old 18th December 2017, 04:49 PM   #8
wdecho is offline wdecho  United States
Tapping raises the hole ever so slightly so be sure and sand, file it down for proper contact.
Old 18th December 2017, 05:38 PM   #9
Bare is offline Bare  Canada
Iso alcohol wipes off My genuine Sharpie black like it was never there... with only One swipe.
Easier done than said
Old 18th December 2017, 05:57 PM   #10
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
I gently wipe the mounting tab on TO-220 packaged devices, across one of those DMT Diamond Whetstones. Takes off microscopic burrs and, I assume, unwanted Sharpie juices.
Ink and heat transfer?Hide this!Advertise here!
Space Heater Project, Heat Transfer Questions kelticwizard The Lounge 17 9th January 2014 02:52 AM
heat transfer of MOSFET to heatsink jdg123 Pass Labs 12 7th August 2013 11:46 PM
Improving heat transfer of ICs uncle_leon Chip Amps 64 15th July 2011 10:36 AM
Heat transfer sompound and mica , silpads etc dhole Pass Labs 1 29th April 2005 04:45 PM
Is solder a good heat transfer medium? leadbelly Parts 3 11th March 2004 03:33 AM
