A First Watt Car Amp!!
Old 30th November 2017, 11:50 PM   #11
WBS is offline WBS  United States
Originally Posted by Doppler9000 View Post
“…my VW Rabbit diesel. It sounded great…” ≠ “Sound quality and car is oxymoron(ic)...”
Why not? It's simply one example.
I agree with res07njc. If it makes you happy to explore your passion go for it!
However, no matter what you do or what car you put it in, or how much money you spend, it'll never come close to something like a properly set up FirstWatt J2 in a living room. (Unless maybe you're parked with the motor off in the wilderness.
"Why do we try to fool the ear? Because it makes people happy and it makes it easier to listen to stuff."
Nelson Pass, BAF 2012
Old 1st December 2017, 02:25 AM   #12
Doppler9000 is offline Doppler9000  Canada
One example disproves the thesis, doesn't it?
The concepts are either mutually exclusive or they’re not.
I am not the OP. I chimed in because I found the response to the initial query to be gratuitous and counterfactual. Passion and curiosity ought to be encouraged, I believe.
I am guessing we all agree on this.
Old 1st December 2017, 03:12 AM   #13
Again, you missed the point. My example implied it sounded great for what it was, a car stereo, not a high end audio system.
Whether someone chooses to be pedantic or not doesn't change the fact that an automobile is a sub optimal environment in which to appreciate the benefits of Class A operation.
Old 1st December 2017, 07:59 PM   #14
bigfishe is offline bigfishe  United States
I got out of car audio a long time ago but this year at the DIY Audio competition in Dayton
I went out back and heard some amazing car audio all DSPed.
I too was thinking a car system was not the ideal environment but man I was proved wrong!
Old 1st December 2017, 08:53 PM   #15
Well, be sure to keep us posted on which direction you take and how it works out.
I actually recall recently seeing a thread that mentioned using the MoFo for car audio.
Old 1st December 2017, 09:05 PM   #16
merlinx76 is offline merlinx76  Canada
It's kinda like listening to headphones that you can feel. No reason why it can't sound pretty damn good if you put the resources into it. It isn't ideal, but neither is your average room by a long shot.
Old 1st December 2017, 09:43 PM   #17
I got your points.
You believe that car stereos don’t sound as good high-end home stereos, and that cars are not the optimal place to enjoy all of the benefits conferred by Class A amplification.
These points are strawmen.
No one has suggested that a car is optimal for sound quality. The OP said he wanted a car with good SQ. He likely believed that readers of the thread would understand the context of the question, i.e., that the stereo would be in a car and not a home, and that the resulting constraints would be understood.
A bit sad that using standard definitions is described as “pedantic” – sign of the times, I suppose.
In any case, this thread is sufficiently soiled – apologies to the OP to the extent I contributed. I hope someone who can help you with your project will respond.
Old 1st December 2017, 09:59 PM   #18
llwhtt is offline llwhtt  United States
The only sound system a car needs is two 2 1/2" - 3" speakers under the rear bumper!
Craig
Old 23rd March 2018, 02:21 AM   #19
pcb121055 is offline pcb121055  United States
Hey Bigfishe... did you give this a shot? Any progress?
Old 23rd March 2018, 03:56 AM   #20
stocktrader200 is offline stocktrader200  Canada
llwhtt , and a sweet V8 to drive them !!
A First Watt Car Amp!!Hide this!Advertise here!
What make and model are the original drivers in Wilson Watt&Puppy 7 (WATT) aguiarrj Multi-Way 17 24th June 2017 10:39 PM
Driving high watt speakers w/lower watt amp? bwolf Chip Amps 15 9th February 2016 11:28 AM
2.3 watt x 4 or 5 watt x2 SET amplifier using DECWARE Zkit1 and Zkit4 schematics Redwolf92 Tubes / Valves 12 29th October 2014 10:19 PM
creating 1 watt rms power from 5 watt chip amp? realflow100 Chip Amps 51 16th January 2013 11:35 AM
400 Watt in 8ohms/ 800 watt in 4 Ohms samp78 Solid State 8 19th November 2012 12:36 AM
Copyright ©1999-2019 diyAudio
