And, if you really want to bark at the moon you can power your compression driver amp with a battery.
When you attach wires to the PCB mounted screw terminals do you then tin the wires or just twist the cores?
I am about to mount wires on my MoFo project and has a doubt what will be the technical most right solution. For the ACA I mounted special terminals for this purpose but for MoFo I will just mount the wires directly in the screw terminals. I would like to tin the wires as this makes them more robust to mount and unmount several times......but I don't know if the tin will "float" during long time presure so connection will be bad over time?
Ok still haven't started my MoFo too many other things happening!
As I plan to use these for my mid range horns which run from about 400hz up I've been looking at other inductor options. Just checked my leftover xover parts and I have a couple of options:
P-Core 14mH 17AWG 0.592 Ω
P-Core 4.7mH 15AWG 0.224 Ω
I also have some good capacitors around the 20-30uf range.
My plan is to use a 19v laptop supply and the drivers are 16ohm.
Are these coils suitable for my freq range? What about the caps, do I need to go bigger?
