Build This MoFo!
Build This MoFo!
Old 9th September 2019, 05:27 PM   #2241
TYM is offline TYM  France
TYM's Avatar
Good morning gentlemen,
concerning mounting the transistor on the heatsink surface:
I can see, in all your pictures, two possibilities:
- press on the heatsink with a small beam or
- fix with a screw through a washer
Which of this option is the most effective? Maybe a beam of wood for a better insulation?
Thank you
Musically yours
Old 9th September 2019, 08:22 PM   #2242
dliscomb is offline dliscomb  United States
dliscomb's Avatar
TYM, unfortunately, I think the answer is 'it depends'
I don't pretend to be a materials science major with a minor in thermodynamics, but for the purposes of heat conduction, either approach will work.
- If you're building a one-off to see how it performs, then the 'beam' mount seems like it'd be easier. I can imagine bolting the beam to your heat sink without making any holes in the heat sink. It would also allow you to try more easily different transistors, if that's your thing. The beam really shouldn't be the heat conductor, but should be sturdy enough to cause the transistor to have even contact across its reverse face.
- If you're building the amp to be The Power Amp for you, and you are comfortable using a tap to create screw threads in your heat sink, then the fixed screw method might be better, as a tidier and more 'permanent' solution. The washer + lock washer is pretty all required, as the lock washer helps you regulate the pressure, and the washer spreads the pressure out over the entire body of the transistor. (props to ZenMod for that advice)
Kind regards,
Drew
Old 9th September 2019, 10:31 PM   #2243
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Build This MoFo!
hardly anything of my own invention there ........ I'm just hysterical enough , to scream all the time what's proper engineering practice from Yore - split washer and big washer , wherever you have heat-cycling present
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 10th September 2019, 11:25 AM   #2244
TYM's Avatar
Thank you Drew and Zen Mod for your support...
Old 10th September 2019, 11:44 AM   #2245
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
Build This MoFo!
Nice Mofo you got there Drew. Congratulations!
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 10th September 2019, 05:14 PM   #2246
TYM's Avatar
Dear gentlemen, do you know when the PCB will be available on the DIYaudio store?
Old 11th September 2019, 06:08 AM   #2247
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
I've some boards etched .
Old 11th September 2019, 11:32 AM   #2248
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
Build This MoFo!
I just sent files to management a few days ago.
Visit AudioMaker.Tech
Build This MoFo!Hide this!Advertise here!
Adapt Polk Audio R20 for Classix II build or build box? unpredictableape Multi-Way 3 3rd April 2017 07:25 AM
Power Acoustik MOFO 10, need box dimensions Spuddd Subwoofers 2 5th January 2017 10:46 AM
LJM MX50-SE - Build Log Gallery & My Build Progress dakku Solid State 3 28th October 2016 08:49 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
Power Acoustik MOFO-10 Sub subwo1 Car Audio 1 24th October 2003 08:12 AM
Copyright ©1999-2019 diyAudio
