Build This MoFo!
Build This MoFo!
Old 1st July 2019, 05:57 AM   #2171
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Build This MoFo!
The IXTK88N30P can handle 600w dissipation vs the IRFP250’s 214w. A TO-264 case also has capability of dissipating more. I would suggest a CPU cooler with heat pipes in order to remove 120w from the MOSFET die quickly enough.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 7th July 2019, 02:13 PM   #2172
plgsekip is offline plgsekip  Indonesia
Default joining the club
Hi all,
MR, thanks for the design. Here is my attempt to build the amp.
Custom ordered choke not the Hammond ones (different specs from the Hammond). Voltage drop across the choke is about 2.7 volt (2 ohms Rdc). Modded a bit to adjust with available components in my drawer. Currently set to about 1 A bias (fluctuating AC mains) and of course, the HS gets really hots after ten minutes of music play. Hunting for bigger HS now....
Once getting a bigger HS, higher bias current will be exercised.
Cheers !
-luq-
Old 7th July 2019, 03:21 PM   #2173
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
Build This MoFo!
Wonderful!
Sorry for my absence, everyone. Some light at the end of the tunnel ahead.
Visit AudioMaker.Tech
Old 7th July 2019, 03:56 PM   #2174
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Build This MoFo!
Mighty ZM thinking of Mr. MR regularly .
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 7th July 2019, 04:19 PM   #2175
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
Thanks Mike for the optimistic news.
Your DIY work share is " the light " to many audio hobby amateurs.
Hooray!
class A amplifiers with full range speakers
sings like angels in heaven
Old 7th July 2019, 04:22 PM   #2176
Mofo moved me to take a step forward.. thanks Mr. MR..
-luq-
Old 7th July 2019, 04:34 PM   #2177
Soundhappy's Avatar
The Big Lebowski - Dream Sequence One
Big Lebowski Dream Part
MoFo Rock the FUN Party
Old 7th July 2019, 05:16 PM   #2178
Vunce is online now Vunce  United States
Build This MoFo!
I hope the “Tunnel” gets full sunlight very soon Mr. MR
I’ve been thoroughly enjoying the MoFo since the day it was born!!
Thank you.
Old 7th July 2019, 06:35 PM   #2179
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
Build This MoFo!
So good to hear from you Mike! Hope things continue to get better.
Thank you for the Mofo. It totally rocks!
Dennis
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 14th July 2019, 09:02 PM   #2180
stevenrotterdam is offline stevenrotterdam  Netherlands
Would it be possible to build a Mofo With Npn transistors? A Bifo? I got some nice 35 year old battery charger electronics, large heatsinks with 3 x MJ 802 already mounted.
Build This MoFo!Hide this!Advertise here!
Adapt Polk Audio R20 for Classix II build or build box? unpredictableape Multi-Way 3 3rd April 2017 07:25 AM
Power Acoustik MOFO 10, need box dimensions Spuddd Subwoofers 2 5th January 2017 10:46 AM
LJM MX50-SE - Build Log Gallery & My Build Progress dakku Solid State 3 28th October 2016 08:49 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
Power Acoustik MOFO-10 Sub subwo1 Car Audio 1 24th October 2003 08:12 AM
Resources saved on this page: MySQL 66.67% / PHP 52.38%
Copyright ©1999-2019 diyAudio
