Build This MoFo!
Build This MoFo!
Old 14th June 2019, 03:32 AM   #2151
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by Eric View Post
...variations of these transformers...
It is hard to generalize about iron-core windings.
However if the inductance is low, it would be a heavy load on the intended 120V/230V wall-power.
If the resistance is high it would get hot delivering the rated 1,000+ Watts to cook your food.
So there can't be any huge difference between the several models.
120V versus 230V should be a clear difference. I'm thinking most work has used 120V jobs, but some report 230V lumps.
Basically we are using a $300 part for a $30 chore, BUT these over-size parts are cheap or free, so we use a 1KVA part for a 20 Watt job.
Old Yesterday, 08:07 AM   #2152
nzlowie is offline nzlowie  Australia
Originally Posted by Stanislav View Post
The choke is in parallel of the load (your 16 ohm driver) acting as a HP filter like in a 1st order series crossover.
Based on that you need a choke of around 6 - 7 mH, but with very low DCR, eg. 0.1 ohm would be good, lower even better.
Not sure how possible it is to find such a choke that can also handle the current of the MoFo.
Better approach IMHO would be to use whatever high current, low DCR choke you can find and then fit a cap that sets the HP point, in series with the positive input of the driver.
Calculate the value of the cap as for a 2nd order HPF.
Build This MoFo!Hide this!Advertise here!
Adapt Polk Audio R20 for Classix II build or build box? unpredictableape Multi-Way 3 3rd April 2017 07:25 AM
Power Acoustik MOFO 10, need box dimensions Spuddd Subwoofers 2 5th January 2017 10:46 AM
LJM MX50-SE - Build Log Gallery & My Build Progress dakku Solid State 3 28th October 2016 08:49 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
Power Acoustik MOFO-10 Sub subwo1 Car Audio 1 24th October 2003 08:12 AM
Copyright ©1999-2019 diyAudio
