Build This MoFo!
Build This MoFo!
Old 11th June 2019, 05:59 AM   #2141
jwjarch is online now jwjarch  United States
jwjarch's Avatar
Ding, ding, ding!!! You win Steve! It’s a BA3, but not just any BA3. This particular project was procured from none other than 6L6 himself. I feel proud to have a piece of diyAudio build guide history as part of my project. Thanks again Jim!!!
So here’s the mock-up of where everything will live basically. I still need to fine tune the position of the MoFo boards and figure out the left to right to allow for the selector switch and attenuators rods. Coming together we’ll so far though.
I measured my chokes tonight and they are both coming out at about 42mH. The 159zc are spec’d at 60mH with a 15% tolerance. Do I have a garbage LCR meter or does the inductance change depending on current applied and temperature?
File Type: jpg C6332BE2-59C3-42AD-A588-88990B62C221.jpg (981.9 KB, 524 views)
File Type: jpg 0977CD17-340A-4ECA-9B8C-B19F32E09AF7.jpg (800.8 KB, 510 views)
File Type: jpg 0D9FDB70-5516-4C9E-839E-A2836C49EAB9.jpg (686.9 KB, 473 views)
Old 11th June 2019, 08:58 AM   #2142
EmeryBB is offline EmeryBB  Australia
Nice stuff jwjarch,
How are you going to power the whole thing, 2 power transformers?
I'm also in the process of putting a preamp and a big MoFo into the same chassis.
I started a thread in the power supplies section asking about an easy way to power the preamp (requires bipolar supply) and MoFo's, has learnt a few things there.
Old 11th June 2019, 12:49 PM   #2143
Eric is offline Eric  United States
Eric's Avatar
Build This MoFo!
Precise measurement of a choke will depend, precisely, on the frequency that your meter uses to measure it. Inexpensive meters just measure and don't indicate what frequency is used - these probably use DC current to measure. More expensive meters will allow you to select from a small range of AC frequencies with which to measure. Super precise measurement requires an even more sophisticated approach with more equipment...
I think you'll be pleased when you are finished with your BA-3 & MoFo combination - mine sound very nice together!
DIY Theater, Aleph-X Amps, LDR based BA-3 pre, B1 Korg, Pearl II, modified SL-1200 TT, F4, M2, Aleph-J, MoFo, a40, ACAs, FHXL & TB 1772 speakers
Old 11th June 2019, 04:23 PM   #2144
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Build This MoFo!
Beautiful work Jwjarch! Super that it fits all in 2U! Outstanding form factor, albeit with some nifty CPU coolers hanging out the top. Sort of Mad Max look in a way.
Stay tuned for the Wayne's BA 2018 preamp module for the Yarra (or stanalone) as a preamp. I just got the verification build PCBs yesterday. Looking forward the hearing that and how it sounds with my MoFo as well.
The WBA18 is the one on left:
I see you are using the nifty Prasi SMT Cap Mx board for powering the BA3 - those work really well.
I use the Dayton DATS v2 woofer tester in LCR mode and it gives inductance as a function of frequency - nice tool.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 11th June 2019, 05:18 PM   #2145
jwjarch's Avatar
Thanks EmeryBB! I'm going to use the toroid (Antek AS-0520) along with a Prasi SMT Cap Mx board (good call X!) for the BA3 and VSPS dual rail supplies. The MoFo boards will each get a 19.5v, 90W HP laptop power supply. I already modified the cords on the HP supplies to accept the 3 pin aircraft type connectors you see in the photo. I read through your thread in the power supply forum. Interesting initial approach. I didn't want to try and power everything off of the same transformer so I went with the toroid and laptop SMPS's. Good luck with your build!
Eric, thanks for the measurement explanation. That makes total sense. There are too many variables and not always enough standardization of measurements, especially when it comes to audio, i.e. amplifiers rated at a million watts when measuring a millisecond peak wattage at a 1ohm load. Looking forward to hearing this combo sing as well!
Thanks X! I definitely wanted to show off these coolers. They're just too nice to hide inside a case. These Prasi CapMx boards are great! I know they aren't technically a regulated supply though so I hope that doesn't pose any issues with the BA3. The VSPS has onboard SREG using LM7812 and LM7912 so no issue there. Great tip on the DATS! I have it on my birthday wish list already. Also need it to measure some drivers and get more serious about speaker building.
I still haven't gotten much feedback on using 159zc's in parallel. Or would it be better to use them in series? Either way it halves the current that each would see, giving me 4A capability for each channel in theory. In parallel they would be 30mH at 350mOhms resistance. In series, 120mH at 1.4Ohms resistance. I'd like to run with 24v supplies eventually. Pro and cons of this scenario?
Old 11th June 2019, 08:42 PM   #2146
PRR is offline PRR  United States
PRR's Avatar
...using 159zc's in parallel. Or ... series? Either way it halves the current that each would see....
No. All parts in a series circuit get the same current.
3A in 0.3 Ohms (parallel) gives 1V of DC drop which should be acceptable for bias stability.
Old 12th June 2019, 12:03 AM   #2147
jwjarch's Avatar
Thanks PRR. I need to go to EE school for dummies. Do you think low frequency cutoff would be a concern with the zc’s in parallel?
Old 12th June 2019, 03:56 AM   #2148
PRR's Avatar
30mH with 8 Ohms supports any bass you can expect to hear with a dozen-Watt amplifier.
Old 12th June 2019, 02:24 PM   #2149
Eric's Avatar
Build This MoFo!
Originally Posted by xrk971 View Post
Keyword search “microwave oven transformer md803” They measure about 65mH and 0.5 ohms dcr. They are air gapped and good for about 10 A.
XRK: Have you measured any other MOTs? I see lots of interesting variations of these transformers: MD-803 vs MD-903 prefix, AMR vs AMS suffix. Just wondering if you have any ideas what these differences in model number actually mean? They all seem to be from 1000-watt rated ovens...
Old 13th June 2019, 08:58 PM   #2150
Got Foam?
xrk971's Avatar
Build This MoFo!
I have not because I wanted to have matching transformers sonaleays bought same model number. But if PRR says anything above 30mH will give sufficient bass performance maybe it’s not so critical. I think 220v ones will measure very differently. Maybe too much DCR?
Build This MoFo!Hide this!Advertise here!
Adapt Polk Audio R20 for Classix II build or build box? unpredictableape Multi-Way 3 3rd April 2017 07:25 AM
Power Acoustik MOFO 10, need box dimensions Spuddd Subwoofers 2 5th January 2017 10:46 AM
LJM MX50-SE - Build Log Gallery & My Build Progress dakku Solid State 3 28th October 2016 08:49 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
Power Acoustik MOFO-10 Sub subwo1 Car Audio 1 24th October 2003 08:12 AM
Copyright ©1999-2019 diyAudio
