Build This MoFo!
Build This MoFo!
Old 16th April 2019, 12:02 PM   #2001
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
Build This MoFo!
I have not tried the Mofo with Wayne's BA linestage (hopefully next weekend)
but there should be no issue with impedance.
Can't say how it will work with your horns. My speakers are only 89dB/W and
it was perfectly quiet.
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 16th April 2019, 01:11 PM   #2002
jolintsai is offline jolintsai  Malaysia
Originally Posted by Zen Mod View Post
you'll be good , maybe even lesser R in CRC
though , you can always resort to CLC
just solve it on the fly
Thanks Zenmod. It is good to know that! I was thinking that it may be insufficient.
Old 16th April 2019, 11:21 PM   #2003
PRR is offline PRR  United States
PRR's Avatar
everything is possible , even wooden stove
Around 1800, in Philadelphia, they used a wood *boiler* for some years. This powered a water-pump for the city. In the New World, iron was costly, trees were cheap. Fire-box was, IIRC, brick-lined (clay was cheap), fire went through an iron box under the water. But the water chamber was all wood and held steam pressure. Yes, pressure in those days may be less than one atmosphere, and 12" (30cm) was not considered big wood those days. Wood rots slow if constantly wet, anyway replacing large timbers was routine maintenance. A foot of wood is much better insulation than a finger of cork over iron; low fuel consumption. They had some small extra trouble because crude iron, water, and wood together make more trouble than any two alone; also pine and oak together are bad. But it ran for a decade or two before rising water demand and falling cost of iron led to a complete new project. Apparently there were others.
Note that this was used to distill spirits before pumping water. They knew what was important.
Old 16th April 2019, 11:33 PM   #2004
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Build This MoFo!
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 23rd April 2019, 06:00 PM   #2005
Hoopy Frood
Build This MoFo!
Default Fun combo
I briefly tried Wayne's BA2018 preamp with the Mofo. Initial impression
is quite positive.
The preamp, with a 2V input and wide-open volume pot, produced
a clean 7.3V output at ~0.02% distortion. That should correspond to about
6W into 8 ohms.
I'm going to try to listen some more next weekend.
- NP 2002
Old Today, 02:09 PM   #2006
toto34 is offline toto34
Build This MoFo!
Default question
Good evening, gentlemen.
Im a newcomer to this forum so I need your advice.
For the Mofo (version 19 Volts and 193 T Hammond).
I just tested a linear alimantation with a transformer of 300 VA ( 2X15 vots) plus diode bridge and 44,000 F filtering.
I mounted a series of resistors to drain 1.7 A , the voltage is 19.5 Volts in charge.
For this voltage there, the setting of 1.7A is correct?
By thanking you in advance.
Old Today, 02:17 PM   #2007
Zen Mod's Avatar
Build This MoFo!
1A7 is good figure
Old Today, 02:22 PM   #2008
Build This MoFo!
Default remerciements
Thank you again Zen Mode for your quick answers.
Build This MoFo!Hide this!Advertise here!
Adapt Polk Audio R20 for Classix II build or build box? unpredictableape Multi-Way 3 3rd April 2017 07:25 AM
Power Acoustik MOFO 10, need box dimensions Spuddd Subwoofers 2 5th January 2017 10:46 AM
LJM MX50-SE - Build Log Gallery & My Build Progress dakku Solid State 3 28th October 2016 08:49 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
Power Acoustik MOFO-10 Sub subwo1 Car Audio 1 24th October 2003 08:12 AM
Copyright ©1999-2019 diyAudio
