Build This MoFo!
Build This MoFo!
Old 7th December 2018, 06:38 AM   #1621
MEPER is offline MEPER  Denmark
BA-3 pre is also the preamp I will use for MoFo. I am working at the PSU in the moment and have all the parts for BA-3 pre…….apart from the attenuator.
Old 7th December 2018, 12:12 PM   #1622
jostwid is offline jostwid  Switzerland
Originally Posted by noviygera View Post
What will I need to drive the MoFo properly?
you will have to answer two questions to yourself:
"How many volts input into Mofo do i need to get the listening volume i like out of my speakers"
"What kind of distortion would i like to add to the Mofo sound (which is rather neutral..)"
Myself i use the following 4
BA3
LuminAria
NuHybrid (Korg triode with buffer by Pete Millet) in two versions:
without step-up transformer (for high efficiency speakers and low volume)
with step-up transformer
Old 8th December 2018, 11:29 AM   #1623
prazza1 is offline prazza1  France
If the preamp has not enough gain, what do you think about connecting an input transformer of 1:4 for instance. What about driving the Mosfet and the frequency response?
Old 8th December 2018, 12:06 PM   #1624
I am building the BA-3 pre because it has a lot of gain. It is made for power amps that has no voltage gain. In the moment I use a preamp which has max. 10 dB of gain. This is fine for MoFo with 94 dB speakers. It is only low level recordings where I am close to the 10 dB the preamp can deliver. If I want to play very loud I may need a bit more than 10 dB but I also build BA-3 because of other qualities…..
Old 8th December 2018, 03:32 PM   #1625
I would like to use it in biamp in high frequencies since around 300 Hz to up. Maybe I can reduce the value of the choke from 50 mH to what ?
Old 9th December 2018, 12:04 AM   #1626
This issue has been discussed a lot in this thread…...but can't remember the post numbers. I think the purpose was the same......as far as I remember MR also made some experiments with smaller chokes…...maybe he remember where to look back in this thread.
Build This MoFo!Hide this!Advertise here!
Adapt Polk Audio R20 for Classix II build or build box? unpredictableape Multi-Way 3 3rd April 2017 08:25 AM
Power Acoustik MOFO 10, need box dimensions Spuddd Subwoofers 2 5th January 2017 11:46 AM
LJM MX50-SE - Build Log Gallery & My Build Progress dakku Solid State 3 28th October 2016 09:49 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 10:52 AM
Power Acoustik MOFO-10 Sub subwo1 Car Audio 1 24th October 2003 09:12 AM
