Build This MoFo!
Build This MoFo!
Old 23rd October 2018, 09:12 AM   #1511
MEPER is offline MEPER  Denmark
If has been discussed in the thread below where MR made some experiments with smaller chokes not long time ago. Maybe you can get some ideas there:
MoFo inductor options for use above 1kHz only
Old 23rd October 2018, 09:14 AM   #1512
This should be the link:
Old 23rd October 2018, 10:45 AM   #1513
marconi118 is offline marconi118  Germany
in this thread they discuss about less mH to use from 1KHz
I need same 50mH but smaller core and wire for less current
Old 23rd October 2018, 12:02 PM   #1514
woody is offline woody
A Hammond 159zc rated at 2A and 60mh comes close
or at 50mh 1.58lb of # 20 copper wire on a 1" diameter and 1" long
form might work but it would also have 5.27 ohms resistance so it
could get hot if used much above 1/2A.
Old 23rd October 2018, 01:19 PM   #1515
Ok.....so you still want to have full frequency range from 20Hz to 20kHz but just a MoFo that only output maybe 5W instead of 25W?
Then you will probably get more distortion?
There is still the small MoFo that bias at 1.7A.....using the small Hammond choke…...but you need it even smaller...…..
Old 23rd October 2018, 02:36 PM   #1516
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Build This MoFo! Send a message via Yahoo to vdi_nenna
Regarding blowing mosfets, don't know if this affects anyone or if it's truly relevant, but there are IRFP250 mosfets with different specs.
The Vishay/Siliconix mosfets have lower Vgs and power dissipation than the Infineon mosfet. Vgs threshold is lower in the Vishay as well.
IRFP250 MOSFET | Mouser
I build, therefore I am.
Old 23rd October 2018, 02:53 PM   #1517
The Vgs limit for Vishay is still 20V (so my 20V zener will still protect).
https://docs-emea.rs-online.com/webd...6b80e309c4.pdf
The Rds(on) is specified as Vgs = 10V, and 85 mOhm (75 mOhm for the Infinion).
Detailed spec. for the Infinion…..is that IOR (RS link to IOR data sheet)?
https://docs-emea.rs-online.com/webd...6b8079120f.pdf
Old 23rd October 2018, 04:27 PM   #1518
what about triad C-56U 35mH 2A 0.8ohm dcr ?
https://eu.mouser.com/datasheet/2/410/media-1067850.pdf
Old 29th October 2018, 10:03 AM   #1519
tborzic is online now tborzic  Croatia
Hi guys!
Having (more or less) all the parts, a quick question(s), so please clarify for me:
Mr. MR (I have seen it many times written on forum, never gave it second taught, but now when I write it.. has wrote in MoFo document that protection diode is 20V zener. A few pages before ZenMod (and others) suggested that zener should be anything between 6V and 12V (or something like that). So, having both, which should I choose, or, for protection purposes it doesn't matter?
and second, I have seen that output capacitor C2 (6800 uF) has been (mostly) increased to other values, so (again) having some decent quality Panasonics 10 000 uF that should be better than locally available 6800uF, what am I doing by increasing C2 value?
Thanks!
Old 29th October 2018, 10:26 AM   #1520
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Build This MoFo!
there is no practical difference between 6V and 20V protection zener , only that smaller value is sorta more conservative
I've seen myriad times Papa putting 9V1 there, it works and he obviously have them in truckloads quantity
output cap - more capacitance , lower F3 ...... or smaller phase twist on "F3" of interest
as usual in DIY projects - when in doubt , double it
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Build This MoFo!Hide this!Advertise here!
Adapt Polk Audio R20 for Classix II build or build box? unpredictableape Multi-Way 3 3rd April 2017 08:25 AM
Power Acoustik MOFO 10, need box dimensions Spuddd Subwoofers 2 5th January 2017 11:46 AM
LJM MX50-SE - Build Log Gallery & My Build Progress dakku Solid State 3 28th October 2016 09:49 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 10:52 AM
Power Acoustik MOFO-10 Sub subwo1 Car Audio 1 24th October 2003 09:12 AM
