B1 with Korg Triode
B1 with Korg Triode
Old 5th December 2018, 09:49 PM   #431
MEPER is offline MEPER  Denmark
Ok......I was thinking if only one version should be handled (the expensive) then this version would be a little bit cheaper than if two versions should be handled. I would go with the expensive (best components). Compared to the time it takes to finish such an amp.....the price difference is not important for me…...but maybe it is for other…..
Old 6th December 2018, 06:45 AM   #432
avdesignguru is offline avdesignguru  United States
avdesignguru's Avatar
Originally Posted by Nelson Pass View Post
It would probably be something like the difference between $49 and $99 in the store.
I think 50 bucks is significant in a preamp circuit. Is this just a pinout thing plus possibly some resistor values? If it comes down to only making one board version available, I vote for the LS pinout and I can cross the legs on the J113s if I decide to use them.
Old 6th December 2018, 05:43 PM   #433
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
B1 with Korg Triode
Pinouts and resistors.
Old 7th December 2018, 04:06 PM   #434
How about a second set of holes at each jfet location with the alternate pinout? Seems like there is enough room and the double sided through hole plated board construction should make it relatively easy to lay out.
Old 8th December 2018, 08:25 PM   #435
The one and only
B1 with Korg Triode
Done. New artwork will accommodate DGS and DSG pinouts and
current source degeneration resistors on the buffers.
Old 8th December 2018, 10:25 PM   #436
asphalt is offline asphalt
Default Pass B1 Korg
Thank you for your hard work it is appreciated
Old 8th December 2018, 11:55 PM   #437
A Big smile from this particular DIY enthusiast. Lacking an Audio Precision, it would eventually be a helpful starting point to know the recommended plate voltage for minimum distortion, unless Ea = half the voltage present on the supply side of the plate resistor is good enough.
Old 9th December 2018, 01:12 AM   #438
irishpatrick33 is offline irishpatrick33  United States
Just my 2 cents:
I think the true value in DIY HiFi is to create high end audio on the cheap. For those just interested in the savings side and not the high end, there are better alternatives; even kits that are pre-assembled (like Parts Express, etc). Pete Millett has his own schematic and board for which people can source their own components. When considering a $50 difference, I think most would take the plunge for the higher end kit.
So here's one vote for the high end option. I am hoping for a way to get notified when the kit is for sale.
Old 9th December 2018, 06:37 AM   #439
jostwid is offline jostwid  Switzerland
Originally Posted by avdesignguru View Post
A Big smile from this particular DIY enthusiast. Lacking an Audio Precision, ..............
Lacking and Audio Precision as well.....
i use a UCA202 DAC (20$) with my old laptop to do the measurements
Softwares are: Audio Tester, REW and Arta
After having destroyed two DAC i built an attenuator following a schematic by DM JOFFE (?) i found somewhere here around. Helps a lot
I really would want some means to see the distortion when setting the bias for the Korg triode. The changes in distortion pattern are a lot! In my case i use a setting of well out of half supply voltage.
Old 9th December 2018, 06:45 AM   #440
Originally Posted by irishpatrick33 View Post
Just my 2 cents:
Although the B1 is on PassDIY, it sounds like maybe this will be sold through the DIYaudio store. Just get on their emailing list. They usually send out new stock updates.
B1 with Korg TriodeHide this!Advertise here!
Korg NuTube is now available online pmillett Vendor's Bazaar 139 3rd December 2018 07:15 AM
New tube tech from Korg Newk_Yuler Tubes / Valves 38 15th January 2017 02:55 AM
2 X PIONEER CDJ-1000 MK3 PLAYER, Korg M3 88-Key Workstation / Sampler,Yamaha Korg holocoast Vendor's Bazaar 0 22nd August 2009 08:03 AM
tapping into keyboard of Korg Polysix mashaffer Instruments and Amps 0 5th October 2008 02:06 AM
Just ordered a Korg EMX-1 MikeHunt79 Tubes / Valves 5 19th May 2008 09:34 PM
