B1 with Korg Triode
B1 with Korg Triode
Old 15th January 2020, 03:11 AM   #4011
soundwavesteve is offline soundwavesteve  United States
Could the Quad somehow be allowing DC back into the B1K? What kind of cables are you using to hook up the Quad to the preamp....maybe cables are overly capacitive? Does it make that noise when the Quad is attached but not powered on? Does it change with volume?
Old 15th January 2020, 03:39 AM   #4012
pinholer is offline pinholer  Canada
pinholer's Avatar
Originally Posted by soundwavesteve View Post
As a test I lowered the plate resistor of the right channel to 290k (from 330k) but all that did was lower the AC output even more...I went from 2.1Vac to 2.0 . Opposite of what I expected....unless I need to lower the 1K resistor as well. Doesn't less resistance = more voltage in = more voltage out? Even the 1K resistor and Q1 should have been seeing more voltage I thought....
If you plot the load line on the triode curves, you will see that the maximum gain is with a horizontal load line (infinite plate load). This produces the greatest plate voltage swing for a set AC grid input. A smaller plate load (sloped load line) produces a smaller plate voltage swing for the same grid input (and same operating point).
Old 15th January 2020, 06:40 AM   #4013
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
B1 with Korg Triode
Originally Posted by KevinHeem View Post
I know, sorry for lack of details...It's just my frustration coming out. I've been trying to track down noise on the mains line for two days now. I don't know where to begin explaining the steps I've taken trying to track this down. I could write a page at least (I will start a new thread somewhere). Using a borrowed Quad 306 was just the last of many steps in trying to isolate the issue. the result of this attempt was a loud siren like noise coming from the tube. I know this because I can put my finger on the tube and make it stop to some extent.
well , K B1's output buffer is buffering ........ so no way that something is coming back from 306's input and unsettling tube ..... amp doing this will long time ago make your ear bleed and speakers cry
must be something with gnd and used supply for K B1
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 15th January 2020, 03:20 PM   #4014
KevinHeem is online now KevinHeem  United States
KevinHeem's Avatar
B1 with Korg Triode
I think your on to something there. I use a long run of interconnect from preamp to amp (8 ft). No noise with Quad off. No change with volume.
Old 15th January 2020, 05:03 PM   #4015
So the tube physically makes a sound?? Does it happen if the Quad is on, but you use a cheater plug to break the ground connection on the amp? Or use the cheater plug on the preamp? How about if you physically connect the amp and preamp chassis with a wire? Was there any recent change to the wiring in the house?
Old 15th January 2020, 06:02 PM   #4016
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
B1 with Korg Triode
If you suspect cable capacitance, then higher value of output resistor.
Old 16th January 2020, 01:09 AM   #4017
So far....R channel with a 470K plate resistor is in perfect balance with the left channel using the stock 330K. (shrug). Whatever...lol. I have no explanation. It is still a few mV off at low (more normal) volumes, but I can no longer tell, that might even be normal. At least I can enjoy it now and cross my fingers that nothing else goes wrong with it. Running at 21.06Vdc on the supply side both channels, heater is exactly .6Vdc both channels, bias is at 11.0vDC...just cause that's where it ended up lol.
Listening to my Zaph audio two-ways with the B1K, deep imaging and crystal clarity. There is some hum and noise when I put my ear up to the speaker, but 2 feet away you cannot hear it. Though cover is still off at this point.
Old 16th January 2020, 01:52 AM   #4018
KevinHeem's Avatar
B1 with Korg Triode
That’s great news Steve!!!!
Old 16th January 2020, 03:03 PM   #4019
Thanks to everyone who offered suggestions and support!
How's your project Kevin? Any updates?
Old 16th January 2020, 03:32 PM   #4020
krk25 is offline krk25  United Kingdom
Originally Posted by Nelson Pass View Post
As the DC bias on the grid is adjusted (altering the plate DC) you will
vary the gain as well as the distortion. If you have the ability to measure
gain and distortion you could optimise either of these, and occasionally
both. From my experience the 8% difference in gain is a little more than
average. Of course, mine has twin volume controls....
Thank you Nelson. Thus enlighted, I have tried to find a suitable DC value. Unfortunately I do not have a distortion analyser. I found two points one with R: 13.2V DC and left 18.7V DC giving equal gain at 1KHz. Obviously, this gives a very high distortion and is unlistenably soupy.
I found a different point of R: 9.2V DC and L: 11.3V DC giving equal gain. I will listen to this some more today. Here we should be in negative phase H2 at least for the right channel.
All in all very big changes in DC bias are required to change the gain. If this variation is common in Nutubes, I would suggest to redesign the kit for dual volume controls.
I might try another Nutube at some point as mine is one of the howlers
If anyone has a Nutube that does not ring and has more or less the same gain in both channels, I would love to buy it
B1 with Korg TriodeHide this!Advertise here!
Korg NuTube is now available online pmillett Vendor's Bazaar 156 24th December 2019 12:33 AM
New tube tech from Korg Newk_Yuler Tubes / Valves 38 15th January 2017 02:55 AM
2 X PIONEER CDJ-1000 MK3 PLAYER, Korg M3 88-Key Workstation / Sampler,Yamaha Korg holocoast Vendor's Bazaar 0 22nd August 2009 08:03 AM
tapping into keyboard of Korg Polysix mashaffer Instruments and Amps 0 5th October 2008 02:06 AM
Just ordered a Korg EMX-1 MikeHunt79 Tubes / Valves 5 19th May 2008 09:34 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
