The Xmas board (generously gifted by Papa) came with the Toshibas. For a friend, I am about to build a DIY store board with the Fairchilds. I will do an A-B listening test after completion and post my results.
Looking forward to the results!
You realize you to use the exact same components.
Power supply, input potentiometer, resistors, capacitors, zener: all will be the same except for the Jfets. There will be A-B hardwired switchover of source and power amp connections between the two units for instant comparison. Gain matching with pink noise and calibrated measurement microphone.
I have both Toshiba and Fairchild version, they sound identical to me.
Ive built both and they sound the same to me too.
I use Takman Metalfilm 1/2 w. Better then the others. Been there tried them all.
I go with Vishay Dale for now (mostly RN55....learned that from 6L6) but where is your source for Takman? ….HiFiCollective?
When I read how Takman Rex and Vishay Dale RN55 are made they seems quite similar. I have not been able to find out which material RN55 use for the end caps. Takman Rex use brass. Both use copper lead outs and Chrome/Nickle alloys for the element.
Some components seems to have lead outs with some iron in.....else they wont be magnetic I guess…..I suspect it could be some of the small diodes. The lead outs are thin but feels a bit hard to cut.
Hificollective or Partconnexion. I think Dale is a little hard sounding in compare.
Try with a strong magnet. Prp is also unmagnetic but is the worst sounding off them I think. This is from hearing when I was a bit younger. Now I do not think I would be able to hear the difference anymore. Or maybe because I do not try
Pass DIY Addict
Joined 2000
Nice implementation, Marra! I was considering going the LDR route as well - I have a few sets and a dedicated 5v regulator board sitting in my parts box still. For now, I'm using a $20 Chinese 50k stepped ladder. Perhaps I'll wire up the LDR at a later date and see how it compares...
Nice built Marra... what LDR kit is that?
Thanks guys.
The LDR board was from a GB organised by dvb-projeckt some yearsago with the consent of George Strantscheff.
- B1 with Korg Triode
