Hello Meper,
nice to hear from you again!
The adjustment pots are connected. I did not use the pots on the pcb. I wired it
to the backplate pots to adjust also if the case is closed. The wires are underside of the pcb.
I used BOURNS 10kohm precision trimpots (10 turns). Makes exact adjustments easy. But I forgot to make a connection from T7/T8 to the outside of the case.
So, to measure I have to open the case again. Or I have to count the amount of
turns (sure not that exact).
In my combination at the moment with the BA-3 poweramp - the B1 Nutube drives the BA-3 with ease.
But I use a easy to drive loudspeaker (4 Ohm, 91dB/W/m, 2-way d'appolito) and
my BA-3 is running close to the edge (+/-34.9V rail voltage, BA-3 gain stage and BA-3 complementary output board). In the gain stage I use original TOSHIBA JFETs from punkydawgs. They run hot!).
Greets
Dirk
Hi Dirk,
What wire and connectors did you use for the Nutube? I find them very flimsy and they can bend out of shape easily.
Perfect! My speakers are probably around 97db, so shouldn't have any problems.
Depends on the speakers as well as how loud you want it.
Me, I listen at moderate levels to 95 dB loudspeakers. A scope on the
amp triggered for peaks shows about 2 watt peaks unless I am trying
to impress someone.
2 watts is 4 volts peak, which requires about 1 volt from the Korg.
The Korg will reasonably deliver a 3 volt peak before the 2nd harmonic
starts owning the dance floor, and the resulting 12V peak coming
out of the amplifier is about 18 watts.
This would give you the same level I listen to but with an 85 dB speaker.
I think you'll be OK.
I'm building up a store version PCB, here's the part numbers (Mouser) I'm using if anybody is interested -
10ohm 3W 603-FMP300JT-73-10R
221ohm 71-RN55C-F-221/R
270ohm 3W 594-5093NW270R0J
475ohm 71-RN55D4750F/R
1K 71-RN55D-F-1.0K
7.5K 71-RN55C7501F/R
33.2K 71-RN55D-F-33.2K
332K 71-RN55D-F-332K
10K trimmer 652-3386F-1-103LF
10uF 647-UFG1K100MEM
1000uF 647-UKW1E102MPD
9.1v Zener 512-1N4739A
Remember that R1 and the transistors are included with the PCB
Hi Jim, what size are the R1 resistors included in the store kit? Also, what are the 221 ohm resistors for in your BOM? They aren't in the B1 Korg pdf on the FirstWatt BOM.
Thanks!
For the Christmas Korg and Toshiba JFETs measured by Papa 100 ohm resistors are used and as there are no 100 R's in the list they are probably 221 R for J113....as mentioned by Nelson.
I decided to dampen the chassis a bit using bitumen. There was some mechanical ringing when I knocked on the chassis. Now it is "dead" and I think it is an improvement. I had some spikes around 6 kHz when knocking at the chassis using the Focusrite and Arta software. So now I sleep a bit better. It is also nicer feeling lifting the Korg……..
...they are the Source-to-ground resistors for the current sources.
These vary by fet selection, and set the current sources to 6 mA or so.
(Emphasis mine.)
Store PCB are using Fairchild Jfets.
Also, when Nelson says 'these vary by fet selection" that means those particular jfets in that particular bag included with that particular PCB.
... as there are no 100 R's in the list they are probably 221 R for J113....as mentioned by Nelson.
Doesn't matter. The "R1" resistors are supplied with the PCBs and mated to those particular transistors.
Lol... I have no idea. Probably a copy/paste that I didn't edit out.
Lol, thanks for the clarification. Been there, done that I'll remove it from my BOM list.
I made the same experiment as Nelson with Korg to check how much output voltage is needed when playing at normal listening level. I would say the listening level was quite loud. I would never play louder. I played classical music. I used Korg with MoFo and I measured output of MoFo which should be identical to Korg output (MoFo has no voltage gain). I used a DMM set to AC to measure average RMS and then set to Peak hold max. to measure peak voltage. As can be seen average RMS is about 0.5 V and peak 4-5 V. I am surprised that average RMS is not more. Speakers are TG OBL-15. They have a sensitivity of about 94 dB. Room is 30 m2 and distance to speakers are about 3m. So Korg works fine with MoFo if speakers are relative sensitive.
OBL-15 works in quite small rooms. My "HiFi friends" are surprised how loud they can play using small amps like ACA or 7W 300B SET. I wonder if manufactures "cheat" a little bit with how sensitive their speakers are as it is a sales parameter...….
Troels Gravesen warns about "Tinnitus" using these speakers.
10 to 1, or 20 dB is about standard for pk/rms with "good" music,
so there you are.
OK!
Think it was good music. Bach with David Fray. A recent release. This one:
New Releases: David Fray – Bach Concertos for 2, 3 & 4 Pianos; James Newton... - Classic FM
The acoustics is a bit special as it is recorded in a kind of "church building"…….
When we are talking Bach……(also on Tidal). Listen to track 3:
Edin Karamazov - The Lute Is A Song (CD, Album) | Discogs
Toccata & Fuga in D-minor played on a Lute!
I just tried…...but could not do it much better…...Edin Karamazov seems to be one of the better Lute players.....also on a guitar he is quite good.
- B1 with Korg Triode
