how about using J111 J175 Jfets in F5
Old 29th December 2017, 11:16 AM   #41
Nag is offline Nag  India
For example if my JFETS are j113 & j176 have Idss about 35mA. So now How can I reduce it 8ma to 10ma bias with paralleling or in series. I read about cascoding article and honestly I don't have that much basic knowledge to process that information in that article.
thanks.
Old 29th December 2017, 11:23 AM   #42
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
majority of investment in amplifier is going to heavy hardware - xformer , caps , case with heatsinks ;
regarding how big decrease in performance and how small amount of saved greenies , if using any other JFets than prescribed , it's simply not wise to proceed with anything else than real thing
even taking in account that for someone obtaining them is complicated , not just or nothing at all matter of money
If you can't manage to have proper JFets , build some another amp , where you can substitute them much easily ....... or some other amp without JFets
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...İ by Mighty ZM
Old 29th December 2017, 11:33 AM   #43
Yeah right. But some newbies want economy build to dirt their hands for first time builds. Cost is too high after shipping and customs for linear systems jfets. May be Mr. Nelson or someone has some secret circuit for guys like me. If I ask only then Members will provide different ways. I have another project PLH in mind because of absolute parts of Toshiba. any exicon lateral or irf available replacement for irf610 to build PLH ?.
Thank you.
Old 29th December 2017, 11:54 AM   #44
Zen Mod's Avatar
build Babelfish J - using J271 for input LTP and pretty much any IRFP N- channel for output
you can make it even on veroboard or PtP ...... or you can make your own pcbs from pdfs posted in first (old ) thread
instead of IRF610 you can pretty much use any of these - IRF510 , 520, 530 , 610,620,630
higher the number , higher voltage and higher capacitances
Old 29th December 2017, 04:25 PM   #45
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
J76 and J113 are the most likely candidates for this - lower Idss.
You would have to adjust the Source resistors to get the currents into the
right range, and it might be a little funky, but it will work.
Old 29th December 2017, 04:48 PM   #46
indra1 is offline indra1  Indonesia
. . . . May be Mr. Nelson or someone has some secret circuit for guys like me. . . . .
While funky is great, you could also try the 2SJ104BL and 2SK364BL pair for comparable spec but the low noise attribute.
Old 29th December 2017, 05:42 PM   #47
Thank you Mr. Nelson. long search for quest ended here.
Old 29th December 2017, 06:58 PM   #48
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
I suspect there is a typo above, and Nelson actually means the J176 P-channel JFET whose datasheet (attached here) specifies
2.0 mA <= |Idss| <= 25 mA
The J177 has even lower Idss, but DigiKey doesn't sell it as a thru-hole part, only surface mount. Fortunately the DIY-focused vendor "Linear Systems," does sell it in thru-hole.
_
File Type: pdf J174_SST174_P-Channel,_Single,_JFET_Switch.pdf (257.9 KB, 27 views)
Old 30th December 2017, 02:38 AM   #49
_
J176 has higher dissipation rate than J177(260mw). J113 & J176 have around 360mw power dissipation.
Old 31st December 2017, 06:42 PM   #50
The one and only
Actually, measuring my extensive population of these parts,
probably should have said J175.
The J113's come in at around 20-40 mA.
The J175's are 25-30, J176 are 8-15, and P1086 are 20-30.
Regardless of the spec in the old datasheet, this is what I'm seeing.
Getting matches for these is not easy, and for the F5 adjustment of Source
and Drain resistors will be necessary to get a balance.
how about using J111 J175 Jfets in F5Hide this!Advertise here!
Testing fairchild J111 N-channel switch Troy Dionne Car Audio 2 10th May 2016 06:43 AM
Jfets in HK eyoung Pass Labs 0 13th February 2013 01:21 AM
Guidelines for switching N-channel JFETs to P-channel JFETs (and vica versa)? Test Electrix Construction Tips 9 24th January 2011 07:22 PM
Matching Jfets Sunsun22 Solid State 3 20th January 2010 03:08 PM
SiC JFETS revintage Pass Labs 15 27th August 2009 03:43 PM
