Iron Pumpkin(s) and other smaller vegetable animals
Iron Pumpkin(s) and other smaller vegetable animals Please consider donating to help us continue to serve you.
Old 24th January 2020, 01:09 PM   #271
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
autoformer is sort of easier to make and easier to achieve wanted quality .......
no benefits of xformer where you don't need galvanic isolation
horses for courses
post datasheet here , it could be interesting to chat a little
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 24th January 2020, 01:27 PM   #272
qwertyl is offline qwertyl  United Kingdom
horses for courses
Specs here: Sowter
Apart from galvanic isolation transformers provide common mode rejection and easy solution for balanced to unbalanced conversion. Some DACs (e.g. Lumin, PS Audio) have transormer at the output - something to do with getting rid of high frequency noise...
Old 24th January 2020, 03:23 PM   #273
Zen Mod's Avatar
yes , I know all that ..... but as I said - it's matter of concept
if you need galvanic isolation , no other way
if you don't need , then ......
Iron Pumpkin (Bal) is doing all that - you can use both Bal and SE inputs , having both SE and Bal output , while entire shebang being fully differential
buffer in front being part of full package , bringing set of benefits to the table, while galvanic isolation wasn't even counted on , as unnecessary; this is preamp , not I/V stage with attenuating function ......... and - knowing majority of possible scenarios , I wouldn't make one without buffer afterwards
conclusion - even small Swiss Knife must be made properly , with all necessary belts and whistles
edit: as part of the game - if you don't need galvanic isolation , you can always try your TVC using just secondary , in AVC fashion , in both cases driven properly with decent buffer
then leave what you like more
Old 24th January 2020, 05:09 PM   #274
That's a really good idea, thanks!
Old 30th January 2020, 06:11 AM   #275
wtl is offline wtl  Australia
ZM, Package arrived safely Today!!
Many Thank's Steve.
Old 14th February 2020, 06:04 AM   #276
torb is offline torb  Finland
Default Prototype/head-phone amp
Hi!
I've got a quick and dirty set up of my Iron Turtle going. I had though not to post until I make a proper home for it, but that will take at least 2 years (building a kitchen and play room takes priority) so here goes!
The buffers are dual DCB1 with the output resistors removed and grounding as per Tea-bags post. Audio ground is connected to ground on the Turtle pcb. Proper plug and play.
Original B1 can drive Turtle to good sounding results.
The setup is completely silent driving head phones. The sound is just great, I'm able to listen to music for a whole work day without getting tired of it.
For living room use, I took ground and positive phase to the kit version of the sony v-fet part 2 amp. This reveals:
1. My tweeters are cracked by happy babyfingers (domes make funny noises when pushed hard) and my previous source is too crappy to reveal this
2. I have ground loops (probable culprit dac, can't remember amp-wiring but my friend sov has ordered fancy pants rectifiers so will have too inspect soon enough.)
So, amazing head-phone amp and best pre I've had but unable to properly evaluate because of deficiencies in rest of system. Hobby work cut out for 2020!
Thanks ZM!
Old 14th February 2020, 06:38 AM   #277
Zen Mod's Avatar
Iron Pumpkin(s) and other smaller vegetable animalsHide this!Advertise here!
Pumpkin Problems KatieandDad Analog Line Level 37 24th January 2013 11:53 AM
2 x Shuntky + 2 x Pumpkin KatieandDad Swap Meet 3 7th January 2012 10:39 AM
What Barnyard Animals Use for Horn Mouth Disruptor mister pig Full Range 4 28th January 2010 07:08 PM
Ultrasonic Piezo for animals haw Multi-Way 5 18th July 2009 02:12 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
