Which preamp for Amp Camp?
Old 7th February 2019, 04:27 AM   #131
jfuquay is offline jfuquay  United States
Originally Posted by invaderzim View Post
I must have bought the same holder, or half a holder, recently.
Ha! Probably so. I sent Mouser an email when I got my “half a fuse holder.” But I had to admit I got exactly what I ordered. So I ordered the other half along with some other odd pieces I still needed. It’s the select switch that’s been the toughest. Balanced circuits are not the easiest to source parts for. Maybe I just need to go with a relay, but that means more work on the front panel for LEDs and room for another PCB inside the chassis.
Old 7th February 2019, 10:20 PM   #132
elwood625 is online now elwood625  United States
Here's one.
4P4T 4 Pole 4 Position 2 Deck Band Channel Rotary Switch Selector with Knob 714998403735 | eBay
Old 24th February 2019, 03:46 AM   #133
Asedillo is offline Asedillo  Australia
Hello, I am planning to get 2 pcs of the Amp Camp v1.6. Can I use my Oppo BDP-105 as the preamp and I am planning to use the XLR output? Otherwise can I use the Schiit Saga preamp? Thanks in advance
Old 24th February 2019, 04:25 AM   #134
Hi, just wanted to check if I can use my Oppo BDP-105 as a preamp for this Amp Camp v1.6? I am planning to build to pcs so I guess the XLR output can be used? Otherwise can I use the Schiit Saga preamp? Thanks.
Old 24th February 2019, 11:07 AM   #135
astromo is offline astromo  Australia
Can't speak from experience for the Oppo but you can find some thoughts of others out there on the interweb. Here's what my fingers turned up:
Oppo BDP105 as a pre amp - Media Servers & Source Units - StereoNET
According to Schiit website, the Saga has a gain of 1 whether you opt for tube function or not. All the intel I've gathered for selecting a pre- for the ACA is that gain helps. I've got a Schiit Freya running max gain possible (2.5) via its tube buffer and that works a treat for me (speakers are rated at ca. 92dB/W@1m).
If your speakers are really sensitive, using a passive pre- will be less of an issue. Depends on what you've got and what sort of room you're trying to fill with sound ... as far as I know ...
Old 25th February 2019, 02:38 AM   #136
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
This would be a good Preamp for ACA:
The YARRA Preamplifier/HPA for Melbourne DB Group Buy
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 25th February 2019, 04:29 AM   #137
6L6 is offline 6L6  United States
6L6's Avatar
That’s really cool!!!
Old 1st March 2019, 05:06 PM   #138
RafaPolit is offline RafaPolit  Ecuador
RafaPolit's Avatar
Originally Posted by 6L6 View Post
I can't give any specifics yet, but there's going to be something in the store in (hopefully 4 weeks or so) that will be absolutely wonderful.
Was this 'secret' you mentioned a few weeks ago the recently released B1 Buffer with Korg triode? (B1 with Korg Triode)
I'm really interested in some either objective or subjective pros/cons between the Whammy and the B1 Preamp for the ACA.
With a 50K pot, the B1 has a 16dB gain, the Whammy a 14dB so they are pretty similar in terms of matching. Other than the obvious "you get an additional heaphone amp", merely as a preamp, how would they compare in terms of audio quality?
Obviously the easy answer is: build both and test!. That is the most fun as well... alas, knowing a little bit beforehand would help a lot!
Thanks for all this, its so incredible to have stopped spending in off-the-shelf equipment to actually have so many options for the DIYer. Thanks!
Best regards,
Rafa.
Old 1st March 2019, 05:09 PM   #139
6L6's Avatar
Nope.
Old 1st March 2019, 05:20 PM   #140
RafaPolit's Avatar
Oh, dammit... even more choices?? That is just crazy. Ok. Even more fun then.
Thanks.
Which preamp for Amp Camp?Hide this!Advertise here!
Amp Camp #1 PCB Rudi_Ratlos Swap Meet 43 30th September 2018 11:12 AM
FS CCS BOSOZ boards and Amp Camp Amp Kit repycte Swap Meet 4 31st May 2017 11:17 AM
Pass amp camp tominredbank Pass Labs 2 26th January 2017 02:57 AM
Amp Camp-tweeters 2meke Pass Labs 2 13th December 2014 09:27 PM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Copyright ©1999-2019 diyAudio
