Sony Vfet Illustrated build guide
Old 4th May 2019, 01:53 PM   #781
dantwomey is offline dantwomey  Canada
Originally Posted by Rodeodave View Post
dantwomey, V-Fets are normally open devices, which means they will conduct current from drain to source even without a voltage present at the gate. This is why the bias supply is so important, the V-Fets have to be turned off or "throttled" before the supply at T3/T5 is present, otherwise they'll burn up.
For the first startup we want the V-Fets turned off (or throttled) more than necessary, just to be safe. The 2sk82 needs a negative bias voltage, so we initially make it more negative than necessary. The 2sj28 needs a positive bias voltage, so we initially make it more positive.
Many thanks for the explanation.
Old 5th May 2019, 09:31 AM   #782
Arye is offline Arye  Israel
You were right, I made an error with one of R15/16 on each board, while replacing to 470R.
Now everything is by the manual.
Thanks for the attention.
Old 5th May 2019, 02:34 PM   #783
A couple suggestions that made testing quite a bit easier was the cheap multiple DMMs with alligator clips installed. And,the following test pins installed at key points on the board.
3136-3-00-15-00-00-08-0 Mill-Max Manufacturing Corp. | Connectors, Interconnects | DigiKey
Dan
Old 15th May 2019, 11:32 PM   #784
VFETs installed and powered up on one channel. T18 to ground .008mv. DC offset at speakers terminals 17mv. R32 5mv. P1 and P2 seem to have a perfect relationship with adjusting T18 to ground.
Dan
Old 15th May 2019, 11:47 PM   #785
Just got time today to power up one channel and tinker for a few minutes. As previously stated. P1 and P2 seem to easily zero out T18 to ground. DC offset at speakers is easily sub 50mv for now. Have not got R32 to rise yet. Still sitting near zero.
Dan
Old 16th May 2019, 10:14 AM   #786
Another brief update. So far perfection seems to be within easy reach. P1 and P2 seem to easily balance out T18 to ground while controlling R32. It was easy (once gain) to get the desired 100mv while DC offset remains stable and low. More soon.............
Dan
Old 18th May 2019, 12:51 AM   #787
Strange feeling when you follow the instructions and everything works out perfectly! ��
Old 20th May 2019, 08:30 PM   #788
Oooops! May have spoke too soon!
Slightly running away DC offset on one channel even though R32 is perfect and T18 to ground is under 100mv.
Questions.
Is R5(T6 and T7) and R6 (t8 and T9) supposed to be the same 1.5V after the VFETs are installed?
Dan
Old 20th May 2019, 09:53 PM   #789
R5 and R6 were around 1.1-1.2V so with meters installed I adjusted them back up (using P3 and P4) to 1.5V while keeping an eye on T18 to ground. So far this has not helped. My DC offset keeps drifting higher. About 2-3mv per minute.
Everything else seems normal. P1 and P2 keep T18 to ground inline much the same way the first channel did.
More to come.....
Dan
Old 20th May 2019, 10:30 PM   #790
After an hour and fully up to temperature we're at 98mv DC offset. Poor VGS matching?
Dan
Sony Vfet Illustrated build guideHide this!Advertise here!
Aleph J illustrated build guide 6L6 Pass Labs 3645 Yesterday 06:18 PM
F5Turbo Illustrated Build Guide 6L6 Pass Labs 564 16th May 2019 02:25 PM
BA-3 Amplifier illustrated build guide 6L6 Pass Labs 224 11th May 2019 06:40 PM
F6 Illustrated Build Guide 6L6 Pass Labs 1311 4th May 2019 10:31 PM
ACA illustrated build guide 6L6 Pass Labs 157 1st February 2019 01:02 AM
Copyright ©1999-2019 diyAudio
