Sony Vfet Illustrated build guide
Old 4th April 2018, 07:16 PM   #511
jaab6 is offline jaab6  Canada
Thank you for your help, have been able to set both side, now I have to assemble the amp and
do it with the cover
Old 4th April 2018, 07:42 PM   #512
oups I didn't see the next messages! sorry
Old 19th April 2018, 02:38 PM   #513
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
Hi. Is it mentionned somewhere the recommended chassis for this amp? Thanks
SB
Old 19th April 2018, 03:17 PM   #514
6L6 is offline 6L6  United States
6L6's Avatar
4U deluxe from hifi2000
Deluxe 4U Aluminum – diyAudio Store
Deluxe 4U Steel – diyAudio Store
Old 21st April 2018, 03:36 PM   #515
sledwards12375 is offline sledwards12375  United States
Hello VFET Builders:
I am in the process of getting all of the parts together for my VFET build. A couple of questions. I just read if the MOSFETS I purchased are from Fairchild, I should have increased P3/P4 to 1K ohms. I ordered 500 ohm pots, and the MOSFETS are from ON Semiconductor, which Fairchild is now part of. Should I reorder 1K pots to avoid difficulties when biasing? Is this something that effects some builds and not others?
Secondly, my VFETS have the following Vgs ratings:
2SJ28: 9.6 V 2SK82: 10.3 V
Are these considered a "close enough match" and knowing these values seem somewhat higher than what others have posted, are there any part value changes I should consider before soldering? Thanks in advance.
Steve
Old 21st April 2018, 05:01 PM   #516
wdecho is offline wdecho  United States
Order the 1K pots. You will need them with Fairchild.
Old 21st April 2018, 05:54 PM   #517
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
Yup, if you're using the fqp parts, you'll likely need the 1k pots to get to the higher/lower Vgs as compared to the Toshiba parts.
The VFETs are not matched across polarities (n,p), so yours will work fine.
Gravity - Making the G since 13.7 billion B.C.
Old 21st April 2018, 07:19 PM   #518
Thanks for the quick answers, much appreciated.
Steve
Old 23rd April 2018, 01:26 PM   #519
Arye is offline Arye  Israel
Default Bridging for Monobloks
Hi to all, I plan to convert two amp kits to monoblocks by bridging operation ( I need more power for my Quad ESL63), I’ve acquired two Jensen JT-123-SS transformers ( like the ones in First Watt F6).
I’d like an advice on the proper placement of the trans’ in the circuit. The more simple will be on the input’ or shell I place them after the Jfet transistor (2sk170’ 2sj74) like in the F6 circuit?
Old 23rd April 2018, 03:35 PM   #520
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
input .
don't mess with circuit .
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Sony Vfet Illustrated build guideHide this!Advertise here!
F6 Illustrated Build Guide 6L6 Pass Labs 2178 Today 05:56 PM
Aleph J illustrated build guide 6L6 Pass Labs 5299 Today 03:11 PM
BA-3 Amplifier illustrated build guide 6L6 Pass Labs 325 7th July 2020 02:43 AM
F5Turbo Illustrated Build Guide 6L6 Pass Labs 598 2nd July 2020 10:30 PM
ACA illustrated build guide 6L6 Pass Labs 169 16th June 2020 03:12 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
