Sony Vfet Illustrated build guide
Old 17th July 2020, 05:05 PM   #1151
fabrice63 is offline fabrice63  France
fabrice63's Avatar
It seems that the trimpots are a real "thing" in this build , is the lower the ppm /° the better , like this : Y0056500R000K0L Vishay Precision Group Foil Resistors | Mouser France
price is not a concern for me , i want my amp to be stable
Old 17th July 2020, 05:38 PM   #1152
RainfallSky is online now RainfallSky  Russian Federation
RainfallSky's Avatar
If price is not a concern, those could be one of the best:
j. 1240W (5K ohm @ 5%) (5K ohm)
g. 1240W (500 ohm @ 5%) (500 Ohm)
P.S.: Although I'm not sure if trimpots affect the sound in DIY Sony VFet build..
Old 17th July 2020, 07:09 PM   #1153
fabrice63's Avatar
I already have those trimpots in my F6 , not for the sound , but for the stability , it's all i like to have
Old 17th July 2020, 07:17 PM   #1154
Ben Mah is online now Ben Mah  Canada
Wow! Those are pricey pot(s)!
Old 17th July 2020, 07:27 PM   #1155
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
Price aside, they do seem like nice trimmers. I particularly like their monotonic nature.
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 17th July 2020, 11:39 PM   #1156
Eric is offline Eric  United States
Knows enough to be dangerous
Eric's Avatar
I would think that using a multi-turn pot will pay the largest dividends in terms of setting the adjustments properly. I used single-turn pots that came with the kit and it took a bit of effort tweaking back and forth. Once it was set, I checked it a few times and not I just don't think about it anymore.
DIY Theater, Aleph-X Amps, LDR based BA-3 pre, B1 Korg, Pearl II, modified SL-1200 TT, F4, M2, Aleph-J, MoFo, a40, VFet-2, ACAs, FHXL & TB 1772 speakers
Old 21st August 2020, 03:40 AM   #1157
Joca is offline Joca  Portugal
Hi
I had my Vfet running for a while but one channel did not went so well. I want to rebias the FE and tune the amps. Is it possible to do it without desoldering the vfets and dismantle?
thanks
Old 21st August 2020, 04:57 AM   #1158
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
I've done exactly that. It's possible, but all the pots interact with each other, especially since the feedback loop is closed. Go slowly with tiny changes to the potentiometer settings, let the temperature equalize after each setting. You'll get a feeling for the direction the circuit is going in.
I described my setup in post #88 Sony Vfet Illustrated build guide
Gravity - Making the G since 13.7 billion B.C.
Old 22nd August 2020, 01:43 AM   #1159
i saw it but i dont have 4 DMM. only 2. that way is almost insane to achieve good results. I saw a procedure where we would lift some resistors and other things. But didnt really understood it
Old 22nd August 2020, 05:09 AM   #1160
well, done it with only 2 DMM. just 4 hours.
Sony Vfet Illustrated build guideHide this!Advertise here!
Aleph J illustrated build guide 6L6 Pass Labs 5527 Today 10:16 PM
F6 Illustrated Build Guide 6L6 Pass Labs 2746 Today 02:23 AM
F5Turbo Illustrated Build Guide 6L6 Pass Labs 627 14th September 2020 09:00 PM
BA-3 Amplifier illustrated build guide 6L6 Pass Labs 327 11th September 2020 03:23 AM
ACA illustrated build guide 6L6 Pass Labs 169 16th June 2020 03:12 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
