Sony Vfet Illustrated build guide
Old 1st July 2020, 03:32 PM   #1091
Jim50hertz is offline Jim50hertz  United Kingdom
Ok, so I was able to confirm orientation from datasheets, where I should have gone in the first place!
I've powered up both boards, and with 510r in r34/35 I get around 4.7v across both r34/35 on both boards.
How do I ascertain Jfet idss from this and adjust r34/35?
My voltages are way off from the initial voltages as noted by Nelson. I'm using the Fairchild JFets
Old 1st July 2020, 03:43 PM   #1092
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
There are no source resistors on the jfets so there are running at Idss.
So the voltage drop across R34/R35 is just the Idss times the resistance.
So the current is 4.7V/510 ohm ~ 9.2mA
A lot of numbers are different because with 510R for R35/R34 your mosfets are
now on. (See T6-T7 and T8-T9 voltages).
But things like G-T6 and G-T8 shouldn't change since those are just the rail voltages.
G-T4 and G-T2 also shouldn't change.
Please check these, as well as your raw DC rail voltages.
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 1st July 2020, 04:10 PM   #1093
bajjisw is offline bajjisw  United States
bajjisw's Avatar
And please post a picture of your power supply, especially input and output connections.
Old 1st July 2020, 04:15 PM   #1094
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
Something's not right. G-T6 should be pretty much the full positive supply voltage of 28V.
We need to see pics of the PSU, including transformer wiring.
Gravity - Making the G since 13.7 billion B.C.
Old 1st July 2020, 04:19 PM   #1095
I'm using a bench PSU. This one.
Is this not useable for the task?
Voltages are the same upon checking Dennis
Old 1st July 2020, 04:24 PM   #1096
Ben Mah is offline Ben Mah  Canada
That is a 0-30V or 15V-0-15V supply. You need 28V-0-28V.
Old 1st July 2020, 04:26 PM   #1097
bajjisw's Avatar
One or two ? If two, how are they wired ?
Old 1st July 2020, 04:29 PM   #1098
Hoopy Frood
It looks consistent with setting 28V and getting +/-14V.
I think it's now time to pull out the transformer, caps and the
real power supply.
- NP 2002
Old 1st July 2020, 04:33 PM   #1099
OK, very noob mistake then!!! Oops.
I'm repurposing my Aleph J PSU, I've a new transformer. I build up the PSU and report back.
Old 1st July 2020, 04:34 PM   #1100
Caps are rated 35v, is this OK?
Sony Vfet Illustrated build guideHide this!Advertise here!
F6 Illustrated Build Guide 6L6 Pass Labs 2752 Today 10:48 AM
Aleph J illustrated build guide 6L6 Pass Labs 5528 Yesterday 12:29 AM
F5Turbo Illustrated Build Guide 6L6 Pass Labs 627 14th September 2020 09:00 PM
BA-3 Amplifier illustrated build guide 6L6 Pass Labs 327 11th September 2020 03:23 AM
ACA illustrated build guide 6L6 Pass Labs 169 16th June 2020 03:12 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
