Sony Vfet Illustrated build guide
Old 23rd May 2020, 12:55 PM   #1071
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
Correct.
Q1 n-jfet k170
Q2 p-jfet j74
NPN for Q3 and PNP for Q4, so
ZTX450 for Q3 and ZTX550 for Q4
I can also confirm that Q5 (left position when looking at the pcb) must be P channel, so either 2SJ313 or FQP3P20. Q6 (right position) must be N channel, so either 2SK2013 or FQP3N30.
Gravity - Making the G since 13.7 billion B.C.
Old 23rd May 2020, 01:40 PM   #1072
Dennis Hui is online now Dennis Hui  Canada
Hoopy Frood
Just be careful with the ZTX450/ZTX550 since the "round side" isn't as obvious
as with TO92 parts.
Since your jfets aren't installed yes, can you try measuring their Idss?
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 23rd May 2020, 02:27 PM   #1073
Jim50hertz is offline Jim50hertz  United Kingdom
Thanks for verifying Rodeodave!
I think I've got the ZTX450/550 right, look ok Dennis?
I stuffed them before your post so they're now in the board. How do I go about testing IDSS?
Old 23rd May 2020, 05:51 PM   #1074
Hoopy Frood
Looks fine.
Since the jfets are already in the boards, just continue on.
You can find out the Idss during power up when by measuring the
voltage across R35/R34.
- NP 2002
Old 24th May 2020, 07:38 AM   #1075
Thanks Dennis
Will carry on
Old 28th May 2020, 02:11 AM   #1076
hirscwi is offline hirscwi  United States
I'm getting ready to build one of these amps. I have the boards from the DIY store but the "T" brackets are no longer available. I can make some but it would be helpful if there's a drawing that shows the location of the holes. I'm sure I can determine it but am being lazy and thought I'd ask.
Old 28th May 2020, 04:24 AM   #1077
hates ground loops
Rodeodave's Avatar
I don't think there's a drawing available. You could simply use the pcb as a stencil though.
Old 28th May 2020, 05:56 AM   #1078
RainfallSky is online now RainfallSky  Russian Federation
RainfallSky's Avatar
Here.
I saved them from this thread.
Though I think holes for mounting bracket to UMS heatsinks should be 3mm.
Old 28th May 2020, 09:26 PM   #1079
Originally Posted by RainfallSky View Post
Here.
Thank you very much.
Old 28th May 2020, 09:28 PM   #1080
I will be using K60 and J18 VFETs. Is it satisfactory to measure the Vgs using a Peak Atlas DCA75 or am I better to use the approach diagrammed by Mr. Pass?
Sony Vfet Illustrated build guideHide this!Advertise here!
BA-3 Amplifier illustrated build guide 6L6 Pass Labs 323 Yesterday 02:58 PM
Aleph J illustrated build guide 6L6 Pass Labs 5254 3rd July 2020 02:47 AM
F5Turbo Illustrated Build Guide 6L6 Pass Labs 598 2nd July 2020 10:30 PM
F6 Illustrated Build Guide 6L6 Pass Labs 2113 26th June 2020 08:00 PM
ACA illustrated build guide 6L6 Pass Labs 169 16th June 2020 03:12 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
