Sony Vfet Illustrated build guide
Old 19th May 2020, 01:28 PM   #1061
Jim50hertz is offline Jim50hertz  United Kingdom
Old 19th May 2020, 01:30 PM   #1062
Thanks Dennis. these are what I have. Fairchilds I think. Are there suggested alternative values for the resistors?
Old 19th May 2020, 01:47 PM   #1063
Eric is offline Eric  United States
Eric's Avatar
That's a pretty nice PSU, Berny! With just a CRC, I measured 0.07 mV AC ripple on the speaker terminals. This is one VERY quiet amp!
DIY Theater, Aleph-X Amps, LDR based BA-3 pre, B1 Korg, Pearl II, modified SL-1200 TT, F4, M2, Aleph-J, MoFo, a40, VFet-2, ACAs, FHXL & TB 1772 speakers
Old 19th May 2020, 04:02 PM   #1064
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
Jim, there's a dependency on the Idss of the jfets. If your parts are at the upper
end of the B/BL grade range then may already be fine.
So for now assume you can't adjust the bias current sufficiently high.
Changing out P3 and P4 to 1K is probably the most 'universal' solution though
desoldering pots is a pain. An alternative is to change out the fixed resistors
R34/R35 which should be easier to desolder. You can measure the voltage
drops across R34/R35 to back out the jfet Idss. Once you have that info, you can
work out new R34/R35 values.
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 19th May 2020, 05:09 PM   #1065
Thanks Dennis. I’ve ordered some trimmers and will order some replacements for R34/35. I guess 500r? I’ll try getting the pots out first.
Question, do the Mosfets need matched? And is there any benefit to tracking down 2sk2013/2sj313? Other than avoiding desoldering parts and adjusting biasing approach.
Old 19th May 2020, 08:38 PM   #1066
Hoopy Frood
Matching is not needed for proper operation though some may prefer to use NN and PP
pairs for the two channels. I think you got your kit from the diyaudio store and I
suggest sticking with the Fairchilds. (Lots of excellent builds with those already, plus
the Toshibas are hard to find.)
If you're ordering resistors, maybe both 500R and 750R and choose based on Idss
measurements?
- NP 2002
Old 20th May 2020, 10:55 AM   #1067
Thanks Dennis
Yes I got the kit from the DIY audio store, in the first round of kits.
I've ordered the resistors you suggest plus 1K trimmers.
Would you suggest replacing the trimmers AND R34/35?
Also is there a way to identify idss prior to installation in the circuit?
Old 20th May 2020, 11:08 AM   #1068
Hoopy Frood
If needed, I would suggest changing only one.
- NP 2002
Old 20th May 2020, 11:40 AM   #1069
Thanks Dennis will start with bumping the resistors to 510r and see what happens
Old 23rd May 2020, 09:51 AM   #1070
Just a triple check before I stuff JFets, BJTs and Mosfets, I'm working with the DIY Audio kit, first round.
Q1 - LSK170
Q2 - LSJ74
Q3 - ZTX 450
Q4 - ZTX550
Q5 - FQ3P20
Q6 - FQP3N30
Confirmation much appreciated! And also to check that legendinf on PCB matches the orientation for these?
Thanks!
Jim
Sony Vfet Illustrated build guideHide this!Advertise here!
Aleph J illustrated build guide 6L6 Pass Labs 5293 Yesterday 06:22 PM
F6 Illustrated Build Guide 6L6 Pass Labs 2163 Yesterday 05:23 PM
BA-3 Amplifier illustrated build guide 6L6 Pass Labs 325 7th July 2020 02:43 AM
F5Turbo Illustrated Build Guide 6L6 Pass Labs 598 2nd July 2020 10:30 PM
ACA illustrated build guide 6L6 Pass Labs 169 16th June 2020 03:12 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
