Sony Vfet Illustrated build guide
Old 29th March 2020, 08:02 PM   #1041
anilva is offline anilva  India
Default Finally completed VFET Amp
6L6, thanks for your VFET build guide. After having bought the VFET kit from DIYAUDIO store more than 3 years back, I finally found time to complete the amp. Thanks to the build guide, putting together this amp was a breeze. I managed to setup the VFET bias to 1.5 amps due to big Heatsink’s I had. The amp works wonderfully. The best sound I heard so far. Standout quality is the timbre of voices and instruments.
Thanks Papa for a brilliant design.
I am not fugly in build looks, but quite functional and does the job well. Here are some pictures.
Cheers.
Anil
DIY VFET, J2, F5T, F6, Aleph J, M2 & 45/2A3 DHT SET Amp, Fostex 206 based BLH, Altec 515 LF & 288 HF Onkens, Tannoy HPD Speakers. EMT950, Technics SP10, Garrard 401, TD124 turntables.
Old 29th March 2020, 08:04 PM   #1042
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
Looks great. Congratulations!
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 29th March 2020, 08:41 PM   #1043
6L6 is offline 6L6  United States
6L6's Avatar
Very nice! So glad you like it, the amplifier is genuinely one of the best ever made.
Old 31st March 2020, 06:39 PM   #1044
Default Uneven gain between 2 channels
I have been playing the VFET amp for the last 2 days after the build. I noticed that one of the channels has lower gain than the other one. Is it possible? What should I look at ? Both the channels are biased at the front end and at the VFET similarly.
I will recheck the bias levels once again. There seems to be atleast 3dB difference between the two channels. One Channel has VFETs marking of 81 and 89 and the other channel has 81 and 94 for vgs measurement. Could this be the issue?
Anil
Old 31st March 2020, 06:49 PM   #1045
Hoopy Frood
The markings and bias should not have the effect you noted.
Did you make measurements? Trying switching inputs, etc?
Also have a look if R3/R4 values are correct.
- NP 2002
Old 1st April 2020, 07:33 AM   #1046
Thanks. The problem seems to be from the vintage yamaha preamp, which has a sticky volume control.
Anil
Old 3rd April 2020, 05:06 PM   #1047
vuongan is offline vuongan  United States
Default My Vfet Amp
I am gradually completing my vfet amp project after 3 long years
there are a few small changes, instead of using the T heat sink I made into the U heatsink, helping the PCB parallel to the heat sink, saving maximum space inside the chassis
Chassis size now: outside 400 x 320 x 120, inside 235 x 300 x 115, compact for a class A amplifier, I like that
I am having a small problem with my amp, and need your comments and help:
currently i am using 2 separate sources for 2 channels of amp, I have yet to match the mass scores of the 2 channels with the overall mass points of the chassis,
2 channels that work individually are perfect
but I can't bring them to the overall mass point of the chassis, because between the 2 points of the 2 channels mass appear voltage of 12.3 AC, My scopemeter died a B channel when I accidentally created a common point between the two amp channels, I don't know why?
,Why Why Why??? I have checked the rectifier diodes, there is no AC voltage detection between them, the DC sources are clean sources. Can someone help me, tell me what should I check?
and I am designing the front of the chassis, can someone give me an idea?
Old 3rd April 2020, 05:59 PM   #1048
Default My Vfet Amp
The problem was solved, because I used the same source for the speaker protection.
thank everyone !
Old 11th April 2020, 06:06 PM   #1049
Bones13 is offline Bones13  United States
Techie Wanabe
Bones13's Avatar
Started back working on my VFet amplifiers (monoblocks) I was chugging along there awhile back, and up to the point of doing adjustments, when I figured out that I had PSU issues. First, I had the wrong transformer voltage (too many different VFets out there, and I picked wrong, not terribly. I also, at that time, could not get the DIYAudioStore power supply boards, as they were out there for awhile. I used a set of PSU boards from ebay, and one of them shorted out right off.
I did start with the full VFET kit from the store, including store matched input transistors.
I took some time off, putting my Aleph J back in service, and subsequently I am using McIntosh MC60 amps, that my dad had in the attic, and getting them reconditioned.
With the enforced home time due to Covid-19, I decided to give them another shot, and got new Antek transformers, and new PSU boards from the DIYStore. I put all that back together on the first monoblock. PSU voltage now 28 as per spec. After an initial setting of values for 1.2v, 1.2v, 100mv, and 0.4mv offset, I tried some rather non-sensitive speakers, and got a bit of sound out. I let it run for a bit more, re-did the values to the above numbers, but when I hooked the speakers back up no sound at all out of the amp. The transistors are all warm, not hot, all the LEDs are lit, and the settings are staying stable. No magic smoke, no pops, no scorched components.
I'm not sure I have the enthusiasm to update the PSU+transformer in the other box at this point.
Where should I even look?
M2x monoblocks - Zu Audio Druid V
(Analog) Technics SL-1200G - K&K Audio Maxxed Phono. (Digital) Bricasti M12
Old 11th April 2020, 06:10 PM   #1050
Rush is offline Rush  United States
Post detailed pictures please.
Might be something over looked. Like input wires crossed.
Rush
Sony Vfet Illustrated build guideHide this!Advertise here!
Aleph J illustrated build guide 6L6 Pass Labs 5254 Yesterday 02:47 AM
F5Turbo Illustrated Build Guide 6L6 Pass Labs 598 2nd July 2020 10:30 PM
BA-3 Amplifier illustrated build guide 6L6 Pass Labs 322 2nd July 2020 10:45 AM
F6 Illustrated Build Guide 6L6 Pass Labs 2113 26th June 2020 08:00 PM
ACA illustrated build guide 6L6 Pass Labs 169 16th June 2020 03:12 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
